-   -   Beam to floor joist connection? (http://www.diychatroom.com/f14/beam-floor-joist-connection-150163/)
daltinator 07-13-2012 09:05 PM
1 Attachment(s)
I attached a picture to easily explain. How do I attach a beam to the floor joist securely. Header that the beam will carry spans over 4 joist. Header will carry about 1/4 of the load up top(another floor plus osb roof and asphalt shingles) Cannot connect to bottom floor of basement because it would block a basement window. Thanks
woody4249 07-17-2012 03:21 PM
I would check your local building codes.
My understanding is that the total weight has to be transferred to the foundation. If a window does not allow direct vertical transfer, then a header needs to be placed over the window and supported by a post or column either side and attached mechanically to the foundation with all the joints be strapped
Mike.
