Beadboard Chair Rail Over Uneven Walls - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-20-2009, 04:32 PM   #1
Beadboard chair rail over uneven walls
I've googled everything I could thing of, but haven't seen this mentioned, although it has to be a common problem.
I'm remodeling a bathroom and want to do a 5' beadboard chair rail. I already have 4' of drywall at the top of the wall. I started putting up 1/2" OSB backer below that yesterday and ran into a problem where my backer is sitting out from the window frame on one side.
Of course, the reason for this is that the studs don't line up nicely down the wall.
Is there any way to "fix" this? Or to make up for the error when I go to place my beadboard?
pmoe is offline   Reply With Quote
Old 02-20-2009, 04:53 PM   #2
the Musigician
DangerMouse's Avatar
the first pic looks like there's foam behind it pushing it out? grab a steak knife and flatten it, if so.
DM
Old 02-20-2009, 04:56 PM   #3
There is foam behind it, but that's not what's pushing it out. The studs are off. This isn't the greatest picture, but you can see the gap behind the beadboard when it's sitting flush against the next stud over.
Old 02-20-2009, 05:26 PM   #4
Crazy, but lovable
flyboy2610's Avatar
How far off are the studs? You will probably need to pull the OSB and use a plumb line to determine how far off the studs are. Then your choice is to either trim the high studs back, if they are deep enough to do so and maintain structural integrity, or cut furring strips and bring the low studs out to the high ones. Which presents problem with the window framing being too far back from the wall surface, and the need to reset your outlet boxes. Or you could go along the wall and replace the studs one by one.
Personally, if it were me and studs would allow it, I'd trim the high ones back. You may be able to install a sister stud along side any that you trim back. Check with you building inspector before trimming the studs.
No matter what you do, you've got some work ahead of you. Good luck!
flyboy2610 is offline   Reply With Quote
Old 02-20-2009, 06:04 PM   #5
Rewards Points: 1,910
You're going to need to do some work on that window sill and side casing anyway cause it's a bit worn and when you put on the beadboard it'll probably all be proud of it out so it. So take off the osb and shim (or you could plane off high spots) to get a nice flat plane (particularly around the window).
You've got enough room to put a new bigger sill right on top of the old one (cut the old sill back so you can hide it behind the beadboard or a new piece of trim). Put on new wider side casing to meet the beardboard. So is the drywall and beadboard going to match up depth wise where they meet the window casing. If not you'll have to do a little additional work there.
Old 02-20-2009, 06:22 PM   #6
Good advice above.
I routinely see studs off parallel in the work we do on old homes. Take the time to bring that new wall out or trim studs back whichever will keep the window in line and parallel with your new wall. Maybe a little of both, but do it now before you regret it later. Might be worth it to make sure the window itself hasn’t moved as well.
If you just cut the sill your eye will pick-up the difference very quickly on the finished product and it will look like you did just that.
We’ve often ended up adding studs to an entire wall because things were so far out of line.
Shamus
Shamus is offline   Reply With Quote
Old 02-20-2009, 06:31 PM   #7
Old School
Willie T's Avatar
You can easily "un-bow" a 2 x 4 by dropping your skill saw blade into the most protruding part of the bow.
Pull the saw out, and tow nail the top and bottom pieces back together. One cut almost always straightens out a stud. (not real good for bearing walls)
Willie T
Old 02-20-2009, 07:09 PM   #8
Thanks for the responses.
I have some significant challenges here. The drywall at the top is already up (it more or less looks OK where it meets the window). Foam insulation, electrical, and plumbing are all in place. And some of the studs already have sisters to shore up some termite damage.
If I had my life to live over, I'd probably re-stud the wall and make it straighter. As it is, I'm not sure what the best course of action is. BTW, this is an exterior wall (an old porch that was framed up to be a bathroom).
These pictures aren't the greatest (it's hard to hold a camera in one hand and hold a level up, in a dark room), but will give you some idea of what's happening. It looks like the corner is sitting way out relative to the first stud.
Old 02-21-2009, 10:27 AM   #9
If the top portion is ok with drywall then leave it alone. Build out the bottom half (wainscoting)to level and parallel using shims, blocking, whatever you need to create a solid backing to nail to. Allow that bottom wall to stand proud of the top drywall and put a cap rail on the top. If you can you might even consider making the window sill as part of that cap.
Shamus
Installing Chair Rail up staircase? tomrash Carpentry 7 07-14-2011 01:42 PM
Chair rail angle cuts...any tips? jn_talbot Carpentry 2 09-18-2008 03:22 PM
decorative trim and chair rail. What are the rules to make it look good? Bacardi 151 Carpentry 10 10-18-2007 02:37 PM
Adding a chair rail to dining room which is connected to kitchen Bacardi 151 Interior Decorating 7 07-05-2007 04:31 AM
Wall lamps and chair rail alvanos Carpentry 1 04-26-2006 12:35 PM
