Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 01-09-2011, 10:25 PM   #1
Post
Beadboard Ceiling
Hello everyone.
I live in a 1960's farmhouse that has mostly plaster walls and ceilings. In a office area I am wanting to install beadboard to the ceiling. My questions are.......
Can I nail to plaster? If not, I am guessing I could use floor adhesive to attatch the beadboard to the ceiling.
I am planning on useing 8' planks that are tounge and groove. The only problem I can forsee is I would have to wait for each board to dry before I hammer another board into place.
If any one has ever had this issue or can give me some advise, I sure could use it.
Thanks,
Tooter
Tooter is offline   Reply With Quote
Old 01-09-2011, 10:47 PM   #2
Beadboard Ceiling
Ok I have seen this done before, as the walls were plaster they applied ¾’’ plywood with liquid nails and attached it to the walls and also screwed the plywood to the wall and then used a nail gun to put up the beadboard.
epson is offline   Reply With Quote
Old 01-10-2011, 03:00 AM   #3
Beadboard Ceiling
Windows is offline   Reply With Quote
Old 01-10-2011, 03:02 AM   #4
Beadboard Ceiling
I did something similar in my home. Epson is basically correct - but you want to make certain to screw either the sheets of 3/4" plywood or furring strips into the ceiling joists. Altogether it will be heavy so you need to be sure it is very well secured.
Old 01-10-2011, 12:16 PM   #5
Beadboard Ceiling
how wide is the room and how long is the beadboard? Can't you go perpendicular to the joists and nail drictly into them?
I'd use 1x3 firring strips every 16" depending on the thickness of the beadboard
mrgins is offline   Reply With Quote
Old 01-10-2011, 01:19 PM   #6
Drywall contractor
Beadboard Ceiling
I'd go with the 1"x4" furring screwed/nailed to the joists, then use a brad nailer or stapler to fasten the beadboard to the the strips. The plywood idea is nice, but kind of costly in comparison....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 01-10-2011, 06:22 PM   #7
Post
Beadboard Ceiling
Thanks for all the ideas. The room is about 12' x 10'. I wasn't sure if I could punch thru the plaster with a brad gun and hit the joists. I plan on doing the ceiling kind of like laying a floor and making my seams off set each other every 4 or 5 boards.
I am kind of liking the Cape Cod look, because my office area is a tan and brown with a chair rail. Dark brown under the chair rail. Darker color wood flooring going on the floor later on. A lot of windows in the office that are painted a gloss white along with the chair rail. So I am figureing on white for the beadboard as well.
Was going to stain it a mahogany, but with the dark flooring going in....naaaaa.
Old 01-11-2011, 08:16 AM   #8
Beadboard Ceiling
Maybe going 12" OC would be better.
Old 01-11-2011, 09:52 AM   #9
Drywall contractor
Beadboard Ceiling
Couldn't hurt....
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Beadboard ceiling bigboyjoel Carpentry 32 04-15-2010 12:13 AM
Popcorn Ceiling Repair CecszaR Painting 7 08-28-2009 04:37 AM
ceiling not white cart Painting 7 06-22-2008 08:32 AM
beadboard ceiling in kitchen bernice General Discussion 2 02-23-2008 10:34 PM
