Beadboard - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-29-2008, 09:09 PM   #1
beadboard
I am planning to use beadboard in a kitchen - ceiling to floor. Should I do the walls before installing the cabinets, sink and range? I am also planning on using the beadboard sheets.
nwsummer is offline   Reply With Quote
Old 12-29-2008, 10:02 PM   #2
Yeah, you should go ahead and install the beaded plywood, i'm assuming that's what you're using. That will be a LOT easier than having to cut out around all the cabinets. Just make sure and and mark where the studs are so you can screw your cabinets to the wall.
sausagefingers is offline   Reply With Quote
Old 12-29-2008, 11:29 PM   #3
Registered User
Termite's Avatar
Where you're going to have countertop and cabinets I don't see any point in installing it on those walls. It'll just be wasted material you don't see. If you're using it for a backspash area or above the upper cabinets just cut it to fit.
You sure you want it floor to ceiling? That's not a very typical installation of beadboard...
Old 12-30-2008, 05:45 AM   #4
just a little something to keep in mind on your project.Bead board is wood water from the sink and steam from cooking pots will destroy it fairly quickly.I only mention this because you say nothing of any kind of back splash or protection in these areas.Otherwise my vote is with KC ,mark for your cabinets then put in the bead board that stuff is not cheep so why waste it eventhough its alot easier to do the other way
clasact is offline   Reply With Quote
Old 12-30-2008, 06:54 AM   #5
I agree with whatís been mentioned above on all counts
A whole kitchen done in beadboard is not something Iíd do. Just too much of it. Either do just the ceiling, or just the walls. Iíll assume your using the 4X8 sheets. The thin material looks a bit cheap due to the depth of the bead and any nails used to fasten it will show as a large dimple. Not just the nail head but the area around it as well. The thicker material looks better installed but has a rough surface. You will have to sand the surface before and in-between coats of finish to get it to look good. Thatís true with the board available in my area, anyway.
Itís easier to do the whole wall before the cabinets are in but it isnít that much harder to measure and mark where the cabinets will go and then cut to fit after they are installed. In a typical kitchen youíll be hanging and finishing a lot of beadboard that is covered. As for a backsplash, Iíd steer away from it unless you are locked into using it. Iíve done a few bathroom jobs where the customer wanted it around the vanity to match the rest of the room. Water splashing and spots donít wipe clean easily from a beaded board regardless of how smooth the finish is.
I have done a couple ceilings in beadboard. I would not recommend the 4X8 sheets unless the ceiling is 8' or less in width. It looks terrible otherwise.
If your using individual T&G boards that have a bead that's another issue. No problem doing a ceiling but to install behind cabinets is not something I'd spend my money on.
Just my 2Ę
Shamus
Shamus is offline   Reply With Quote
Old 12-30-2008, 09:14 AM   #6
Thanks for the suggestions. We are redoing a kitchen at a shore house rental. Your thoughts on the backsplash are helpful. We were intending to cover the walls because we took down some old paneling that was glued. We really didn't want to redrywall, this seamed like an easy solution. We will have to give it more thought.
Old 12-30-2008, 12:12 PM   #7
Mold!! Let's kill it!
Rewards Points: 2,012
People you rent to will not treat it the same as you would, so you need to make it bulletproof. Anything that can easily be water damaged by a lack of care is not really a good idea in a rental.
Old 12-30-2008, 06:20 PM   #8
Rewards Points: 150
The prefinished "white ice" beadboard in my opinion would be fine for somewhat wet areas. It has what seems to be some kind of finish or coating that would appear that water wouldn't affect it. Hard to explain I guess. I planned on using it around the back of my whirlpool and for the apron of the deck and tile the deck itself. I know it is masonite backed but the front of the stuff i'm talking about has almost a plastic type finish. I handle it alot at work and some of the "B" grade stuff has spots where the finish is blistered and you can see kind of a plastic type coating. Just my 2 pennies!!!
MikeVila is offline   Reply With Quote
beadboard panel installation (ceilings) t_mccann Remodeling 12 01-05-2013 12:42 AM
Beadboard Backsplash nthomp16 Building & Construction 12 02-06-2011 03:28 PM
Beadboard ceiling bigboyjoel Carpentry 32 04-14-2010 11:13 PM
Beadboard Ceiling kgrotjohn Carpentry 17 05-14-2009 08:57 PM
bathroom and beadboard tanksmom Carpentry 2 05-03-2006 01:52 PM
