Bead Boards - Not Panels - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-13-2009, 04:08 PM   #1
Bead boards - not panels
I need to install bead boards (5" wide) tong/grove over drywall that has metal studs. Suggestions for best method would be appreciated. Several rooms; probably 150 boards that will be 48" high with a chair rail and base added.
Thanks.
cdavidl is offline   Reply With Quote
Old 05-13-2009, 05:37 PM   #2
Rewards Points: 5,336
Construction adhesive and finish nails shot into the tongue until it sets. Occassional face nailing as needed.
Ron
Old 05-13-2009, 05:39 PM   #3
Thanks for the confirmation. My thinking was along the same lines, shooting the nails at an angle. Thanks.
Old 05-16-2009, 06:28 PM   #4
Drywall contractor
Rewards Points: 1,070
Or staples, a bit more holding power in the drywall....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 05-16-2009, 09:56 PM   #5
You may need to remove some drywall to install some solid blocking. In the end, this may be the best option and the finished product will not be at the mercy of the material warping or twisting.
Josh Jaros Remodeling in The Woodlands, Texas www.jarosbros.com
jaros bros. is offline   Reply With Quote
Old 05-17-2009, 04:13 PM   #6
Thank you all for your suggestions. The staples and adhesive is what I plan to use, with some screws into the metal studs periodically. The chair rail and base should hold things together pretty well.
Thank you again.
Paper faced Metal inside/outside corners? slinku2020 Remodeling 6 03-20-2009 11:16 PM
Where to get bathroom panels similiar to rebath? Side panels? twilightcall Remodeling 2 03-06-2008 10:19 AM
hardwood flooring boards matjone Flooring 4 02-01-2008 06:35 PM
