Bead Board - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-01-2009, 04:33 PM   #1
bead board
Can you just use liquid nails to put up bead board? It is the 4/8 sheets and I will only be useing about 30 inch high pieces. Thanks in advance.
jayharold is offline   Reply With Quote
Old 01-01-2009, 04:43 PM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
yes you can, but I would set some trim nails into all the studs the sheet covers. and try to have the laps of the sheets land over the studs as to keep the seems tight , the base and the cap will keep the sheet tight against the wall between the stud spacing. bob
Old 01-03-2009, 10:16 PM   #3
It depends on how flat the walls and the bead board are. I did this in the entry hallway in my house and used liquid nails and can tell you that the wall was not straight and the sheets were not flat. The glue would not have made proper contact with the wall without the help of some finishing nails into the studs. I'm guessing that by now, however, the liquid nails is holding the bead board up just fine.
justin2009 is offline   Reply With Quote
WAINSCOTTING With BEAD BOARD Nathan Carpentry 29 02-24-2013 03:42 PM
Paper faced Metal inside/outside corners? slinku2020 Remodeling 6 03-20-2009 10:16 PM
cutting bead board scatterbrain General DIY Discussions 3 01-09-2008 08:13 AM
Removing water stains bead board Mikon Painting 5 10-08-2007 04:57 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 10:50 PM
