Bathroom Vanity 1/4" Too Wide - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-26-2011, 07:49 PM   #1
Bathroom Vanity 1/4" too wide
My new bathroom vanity is 48" wide and the gap between my walls are 47 3/4". There is enough space to trim the cabinet on both sides but I am not sure of the best tool for the job. Please give me some experience with a new tool or a good idea of what to do.
Thanks,
Jay
Bathroom Vanity 1/4" too wide-dsc_0287.jpg   Bathroom Vanity 1/4" too wide-dsc_0288.jpg   Bathroom Vanity 1/4" too wide-dsc_0289.jpg
lukey19 is offline   Reply With Quote
Old 11-26-2011, 07:57 PM   #2
Not sure I follow. Can you post a picture.
Jmdesign is offline   Reply With Quote
Old 11-26-2011, 08:00 PM   #3
Framing Contractor
Rewards Points: 118
Circular saw with a trim blade will work. Clamp a straight ege on to use as a guide. Check the wall to see if 1/4" is needed the whole way down. You can cut it out of square to match any wall discrepancies.
sixeightten is offline   Reply With Quote
Old 11-26-2011, 08:12 PM   #4
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
It wouldn't hurt to score finish with a knife and/or putting masking tape up the length of the cut.
titanoman is offline   Reply With Quote
Old 11-26-2011, 09:09 PM   #5
Rewards Points: 582
we use and hand plainer and belt sander always does nice job
The Following User Says Thank You to ben's plumbing For This Useful Post:
lukey19 (11-27-2011)
Old 11-26-2011, 09:14 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Probably all you have is a slight overhange to cut away, 1/4" X 3/4" maybe, is that correct?
A router with a bearing-straight-bit would also work or you could just gouge the drywall. I hate it when guys do that but hey, it works.
The Following 4 Users Say Thank You to Bud Cline For This Useful Post:
ben's plumbing (11-26-2011), lukey19 (11-27-2011), Msradell (11-26-2011), oh'mike (11-27-2011)
Old 11-27-2011, 07:03 AM   #7
[quote=lukey19;779560]My new bathroom vanity is 48" wide and the gap between my walls are 47 3/4". There is enough space to trim the cabinet on both sides but I am not sure of the best tool for the job. Please give me some experience with a new tool or a good idea of what to do.
Thanks,
Jay
Someone said to use an Oscillating Tool to cut it. I don't have one but will go buy one if it would work.
Old 11-27-2011, 07:11 AM   #8
DIY staff
Rewards Points: 7,174
Buds method is tried and true----I've done that dozens of times and the cut will be perfect--
However---you must make several passes with the router----tape thin strips of wood or formica to the side so the cut is less than 1/8" per cut---or the bit will cause some splitting.
Old 11-27-2011, 07:24 AM   #9
Disabled wood vet
titanoman's Avatar
Smile
[QUOTE=lukey19;779769]
hank
Lukey- easiet way, already mentioned once: just cut the paper facing on the sheetrock (if that's what is there) with a razor knife exactly where the vanity contacts the wall and tap the exposed (Dolimite) under the paper with a hammer. The sheetrock will crush very easily. Pop that baby in the "slot" you have created and a screw or two and you're done. Botta botta bing!
The Following User Says Thank You to titanoman For This Useful Post:
Old 11-27-2011, 07:28 AM   #10
I posted pictures, does that help?
Old 11-27-2011, 07:52 AM   #11
DIY staff
Lukey----an isolating tool could make that cut but the cut will be uneven.
Do you have a friend with a router? Or a good sharp hand plane?---That cut must look perfect--it's a 'show' cut----A router with a straight cutting bit with a bearing on the bottom (laminate trimming bit)
Is the safest---
A good hand plane will do the same--but few people know how to use them any more---Mike---
(I'm a kitchen and bath guy---along with being a cabinet maker--I've done this many times)
Old 11-27-2011, 11:26 AM   #12
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Power planer
That's what I've been using ever since I heard about them
tcleve4911 is offline   Reply With Quote
The Following User Says Thank You to tcleve4911 For This Useful Post:
Old 11-27-2011, 11:34 AM   #13
Tileguy
Bud Cline's Avatar
Rewards Points: 558
If you are looking for an excuse to buy a new oscillating tool then go buy one but don't try to use it for this purpose, it will not do a very good job and you run the risk of running off-course before you know it. Cut out the damned drywall and be done with it. Cut a channel 5/8" wide and 3/16" deep in the drywall and tuck the cabinet into the channel.
The Following 2 Users Say Thank You to Bud Cline For This Useful Post:
lukey19 (11-27-2011), Willie T (11-27-2011)
Old 11-27-2011, 11:48 AM   #14
Ironlight's Avatar
You don't mention anywhere how far back the cabinet needs to go. That bears on whether the cutting out of drywall is even feasible. If it only needs to go back 1/2" or so then that might be feasible but IMHO it will look like a hack and finishing off the edge of the cut drywall to make it clean and straight is going to be a fair amount of work if you're not practiced in patching and sanding drywall.
I would definitely go the trim the cabinet edges with a router route. You can control exactly how much you take off and have it perfectly even top to bottom. The key is going to be taking off a bit at a time...2, maybe even three passes to get a clean smooth edge on the final product.
All this presumes you know how to handle a router. If you do not, practice a few times on a scrap of similar dimensions to get comfortable.
Ironlight is offline   Reply With Quote
The Following User Says Thank You to Ironlight For This Useful Post:
Old 11-27-2011, 11:58 AM   #15
Vanity problem
tcleve4911
I was now thinking this might be my route. I will let you know.
It has to go back 3 more inches so i don't think I will be ripping out the drywall. The 1/4 is the whole way down the vanity.
Tags
bathroom vanity cabinet
bathroom vanity install questions rtoni Building & Construction 3 09-28-2011 02:50 PM
Painting laminate bathroom vanity perferd Painting 7 12-18-2010 09:48 AM
Bathroom vanity ronklingler Plumbing 1 12-13-2010 05:50 PM
Bathroom vanity surface doesn't join to walls Toe Remodeling 4 10-23-2009 03:53 PM
Bathroom Marble Vanity Sinks Vic&fred Remodeling 1 10-16-2008 02:47 PM
