Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 02-16-2013, 10:22 PM   #1
Question
bathroom floor
My name is Delvia and Im kinda new to remodeling. Right now Im doing a bathroom in a older house that has that 4" concrete slab floor.At first I was just going to remove the tile and use some self leveling cement, but Im have troube removing the tile. Meaning everytime I try the concrete cracks with the tile. I was wondering how hard is it to just pull up all the concrete and just redo the whole floor? Please let me know if you have advice that will help me.
Delvia Carter is offline   Reply With Quote
Old 02-16-2013, 10:28 PM   #2
Trucon01's Avatar
bathroom floor
How big of a floor is this?
Basement Demo started Jan 2012:
Bathroom demo started Feb 2013:
Trucon01 is offline   Reply With Quote
Old 02-16-2013, 10:44 PM   #3
bathroom floor
Its a small bathroom about 40sf
Old 02-16-2013, 11:30 PM   #4
bathroom floor
What are you using to try and remove the tile?
Old 02-17-2013, 12:23 AM   #5
bathroom floor
I was using a sharp edge chisel and a hammer
Old 02-17-2013, 12:27 AM   #6
bathroom floor
A whole lot faster if you use one of these.
http://www.bing.com/images/search?q=...electedIndex=0
You can rent one from Home Depot. They may have a Hilti brand but it sure would be a whole lot faster.
Pretty big job to totaly remove all the old concrete and start over.
Old 02-17-2013, 12:33 AM   #7
bathroom floor
Thanks for the advice
Old 02-17-2013, 07:10 AM   #8
Super Moderator
bathroom floor
Post some pictures if you can-----are you sure that the concrete is cracking?
Could it be a coating of self leveling compound on top of the concrete floor?
Breaking up a floor is possible----but so seldom needed that I think we should see what is going on before you rent a jack hammer----
Old 02-17-2013, 08:47 AM   #9
Nest Home Improvement
NestHI's Avatar
bathroom floor
I have run into this before. What I did was removed the old subfloor since it was so brittle. Once removed I rebuilt subfloor with Durock cement board and then retiled. Since it is a small area, not so difficult to do.
Home improvement simplified! Serving the Triangle (Raleigh, Durham, Chapel Hill). Please visit us at
NestHI is offline   Reply With Quote
Old 02-17-2013, 08:53 AM   #10
Super Moderator
bathroom floor
Nest----I think the OP has a slab----so no subfloor----thus no Durrock could be used for repair---
Old 02-17-2013, 08:57 AM   #11
NestHI's Avatar
bathroom floor
Thanks. I didn't see that
The Following User Says Thank You to NestHI For This Useful Post:
oh'mike (02-17-2013)
Old 02-17-2013, 09:56 AM   #12
bathroom floor
okay, oh' mike, here are some pictures maybe they will you a better visual of what Im up agaisnt..
bathroom floor-100_2277.jpg   bathroom floor-100_2278.jpg   bathroom floor-100_2279.jpg   bathroom floor-100_2283.jpg
Old 02-17-2013, 10:21 AM   #13
Super Moderator
bathroom floor
I see old floor joists----right?
Is this a 1900--1930s vintage house? If I am seeing this right--you have a real recessed mud set---
framed floors---wood ledgers nailed about five inches below the top of the joists--then wood 'sub floor' then 4 inches of deck mud packed between the floor joists?
Let us know----if I am wrong and you have a slab on grade---(soil/gravel/with concrete on top) the repair will be different.
Delvia Carter (02-17-2013)
Old 02-17-2013, 01:36 PM   #14
bathroom floor
Think its the slab on grade. I dont see no wood subfloor under. Here are a few more pics.
bathroom floor-100_2286.jpg   bathroom floor-100_2287.jpg   bathroom floor-100_2295.jpg
Old 02-17-2013, 04:59 PM   #15
NestHI's Avatar
bathroom floor
Probably easier to remove it all and start from scratch.
The Following 2 Users Say Thank You to NestHI For This Useful Post:
Delvia Carter (02-17-2013), oh'mike (02-17-2013)
no framing concrete slab bathroom floor needs to be repaired in one spot barrr Flooring 1 05-15-2012 10:01 PM
Help with ceramic floor bathroom lornescot Flooring 0 11-19-2011 01:35 PM
Bathroom floor & shower waterproofing questions hotbread Tiling, ceramics, marble 0 01-24-2011 01:39 PM
New foundation for bathroom floor and exterior wall studs JayG Building & Construction 2 07-11-2010 02:25 PM
Removing concrete slab on 3rd floor bathroom NowItsShowtime Flooring 2 03-26-2009 03:17 PM
