-   -   bathroom floor (http://www.diychatroom.com/f14/bathroom-floor-172139/)
Delvia Carter 02-16-2013 09:22 PM
bathroom floor
My name is Delvia and Im kinda new to remodeling. Right now Im doing a bathroom in a older house that has that 4" concrete slab floor.At first I was just going to remove the tile and use some self leveling cement, but Im have troube removing the tile. Meaning everytime I try the concrete cracks with the tile. I was wondering how hard is it to just pull up all the concrete and just redo the whole floor? Please let me know if you have advice that will help me.
Trucon01 02-16-2013 09:28 PM
How big of a floor is this?
Delvia Carter 02-16-2013 09:44 PM
Its a small bathroom about 40sf
joecaption 02-16-2013 10:30 PM
What are you using to try and remove the tile?
Delvia Carter 02-16-2013 11:23 PM
I was using a sharp edge chisel and a hammer
joecaption 02-16-2013 11:27 PM
A whole lot faster if you use one of these.
http://www.bing.com/images/search?q=...electedIndex=0
You can rent one from Home Depot. They may have a Hilti brand but it sure would be a whole lot faster.
Pretty big job to totaly remove all the old concrete and start over.
Delvia Carter 02-16-2013 11:33 PM
Thanks for the advice
oh'mike 02-17-2013 06:10 AM
Post some pictures if you can-----are you sure that the concrete is cracking?
Could it be a coating of self leveling compound on top of the concrete floor?
Breaking up a floor is possible----but so seldom needed that I think we should see what is going on before you rent a jack hammer----
NestHI 02-17-2013 07:47 AM
I have run into this before. What I did was removed the old subfloor since it was so brittle. Once removed I rebuilt subfloor with Durock cement board and then retiled. Since it is a small area, not so difficult to do.
oh'mike 02-17-2013 07:53 AM
Nest----I think the OP has a slab----so no subfloor----thus no Durrock could be used for repair---
NestHI 02-17-2013 07:57 AM
Thanks. I didn't see that
Delvia Carter 02-17-2013 08:56 AM
4 Attachment(s)
okay, oh' mike, here are some pictures maybe they will you a better visual of what Im up agaisnt..
oh'mike 02-17-2013 09:21 AM
I see old floor joists----right?
Is this a 1900--1930s vintage house? If I am seeing this right--you have a real recessed mud set---
framed floors---wood ledgers nailed about five inches below the top of the joists--then wood 'sub floor' then 4 inches of deck mud packed between the floor joists?
Let us know----if I am wrong and you have a slab on grade---(soil/gravel/with concrete on top) the repair will be different.
Delvia Carter 02-17-2013 12:36 PM
3 Attachment(s)
Think its the slab on grade. I dont see no wood subfloor under. Here are a few more pics.
NestHI 02-17-2013 03:59 PM
Probably easier to remove it all and start from scratch.
Copyright 2003-2014 Escalate Media LP. All Rights Reserved
