Bathroom Fan Wall Caps - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-07-2012, 03:07 PM   #1
I just installed 2 wall caps for bathroom fans. After cutting out a 4" hole, the wall caps sat on top of the clapboards with big gaps behind it on part of the sides.
So I cut out the section of the clapboards for the 6 1/2" perimeter sides. Now the wall caps are flush against the plywood sheathing on the gable side of the house.
What if anything is recommend to be placed on top of the plywood sheathing behind the wall caps for weather protection, or some other reason that I should be aware of?
I was thinking of possibly tar paper, or another 1/2" layer of plywood, or ??
jdjd is offline   Reply With Quote
Old 07-07-2012, 04:15 PM   #2
Rewards Points: 13,250
Post a picture of what you have done.
The siding was suppost to come off, a round hole big enough to have the vent slide in and be flush with the OSB with a hole saw. Nail the nailing fin then if it makes you feel better you can use Tyvek tape or seal sealing window tape around the flange. Then the siding goes back on.
There is another type of vent that is a flush mount but there's differant ones for every differant profile the siding comes in and they can only be mounted right at the lap in the siding. Main reason I just never use them is they look like poop, can leak, restricts where it can be mounted.
Wall box for bathroom vanity light woodardhsd Electrical 8 07-10-2012 05:53 PM
Cutting Wall Caps cibula11 Landscaping & Lawn Care 0 04-29-2011 11:30 PM
Bathroom - Toilet too close to wall? No vent?! mlenihan Plumbing 5 03-27-2011 08:20 PM
Trouble with staggered wall rightit Building & Construction 2 03-09-2011 07:23 PM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 01:55 PM
