Bathroom Door Width: 30 Or 32"? - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-18-2011, 05:06 PM   #1
Rewards Points: 1,062
Question
bathroom door width: 30 or 32"?
i was wondering what most new or remodeled bathroom door widths are. i can go 32 but that would come really close to the vanity when swinging.
thanks
Old 11-18-2011, 05:20 PM   #2
I would always go as wide as you can.....Never know when you might need the extra width (replacing the tub without banging up the tub or door frame?)
That's just my opinion. But it's free, so take it for what it's worth to you.
1910NE is offline   Reply With Quote
The Following 2 Users Say Thank You to 1910NE For This Useful Post:
amakarevic (11-18-2011), Willie T (12-02-2011)
Old 11-18-2011, 05:38 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
why cheap out for the sake of literally $2 or when it comes to going for a smaller door.. you'll be hitting yourself if you ever hurt yourself and are on crutches.. youll find out how hard it is to get through narrow doors while walking on them
there are codes regarding minimum door widths for specific rooms in a house. the only time very small doors dont matter is when it comes to a broom closet or any space that isnt intended for someone to be inside
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
Old 11-18-2011, 08:23 PM   #4
KemoSabe
loneframer's Avatar
32" door
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
loneframer is offline   Reply With Quote
The Following User Says Thank You to loneframer For This Useful Post:
Old 11-30-2011, 10:19 AM   #5
Crusty Old Dude
Big Stud's Avatar
Being a wider than normal person myself, I always go as big as I can
Big Stud is offline   Reply With Quote
Old 11-30-2011, 05:51 PM   #6
MikeKy55's Avatar
Rewards Points: 254
I used 32 in my new basement bathroom.
'It's never too late to say ''THANK YOU'' to a veteran of our armed services'
MikeKy55 is offline   Reply With Quote
Old 11-30-2011, 10:24 PM   #7
Man of many hats
wrangler's Avatar
Rewards Points: 354
thanks
I agree with the previous recommendations for the 32, and as for the vanity you have a few options to protect both the door and the vanity... a spring type door stop attached to either the door or the vanity, a hinge mounted swing limiter or a floor mounted door stop. I prefer the hinge type since it is easily removed if needed and not an obstacle.
Man of many hats
wrangler is offline   Reply With Quote
Old 12-02-2011, 06:17 AM   #8
2' 6" is a standard door for all bath and bedrooms. I would have to see your layout, you could use a 2' 8" door but in a standard bathroom it be a problem where the casing meets the vanity. 21" or 18" deep vanity? good luck.
cbereswill is offline   Reply With Quote
multiple choice - basement bathroom venting debacle and burps denemante Plumbing 1 11-15-2011 11:50 AM
Bathroom to Laundry Room to Bathroom bcatanz10 Remodeling 2 10-10-2011 10:45 PM
Wondering if it makes economic sence to replace a bathroom exhaust fan ChrisJJ HVAC 0 06-14-2011 11:36 AM
How to select appropriate Bathroom Lighting crescentharbor1 Kitchen & Bath Remodeling 1 02-28-2011 10:47 PM
Basement bathroom wiring mess. Little help. trailblazer1229 Electrical 15 02-16-2010 10:29 AM
