Bathroom Crown Molding - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-10-2012, 05:40 PM   #1
I would like to install 3" Crown Molding in our bath. I will be installing a larger than needed exhaust fan.
Even with the fan, this location tends to be a high moisture area at times.
What type of material should the molding be or not be made of ?
I will use a good sealer/paint and use mildew resistant caulk.
Thanks for any advise.
stymie222 is offline   Reply With Quote
Old 12-10-2012, 08:22 PM   #2
they do make a plastic or polyfoam crown. the big orange place carries some of it
Old 12-10-2012, 09:24 PM   #3
chitownken's Avatar
Rewards Points: 510
I would avoid MDF trim. MDF swells with moisture. PVC or similar plastic would probably be the best choice. Think that foam would hold moisture and tend to promote mold growth. I have poplar trim on my bathroom, but primed and 2 coats of paint on the back side as well as the front. Been a little over 7 years since I put it up and no issues so far. Do have high CFM fan and we are religious about running the fan at least 15 minutes after done showering. Get a timer for the fan if you don't have one already.
chitownken is offline   Reply With Quote
Old 12-11-2012, 04:11 PM   #4
AHH, SPANS!!!
Rewards Points: 1,166
a pvc crown would work or a good stain grade crown without finger joists in it.
hand drive is offline   Reply With Quote
Old 12-11-2012, 06:10 PM   #5
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,250
clear pine is the most economical. .the foam stuff needs to be glued and nailed really well because its so flexilble, typically sets of 3 nails every 8-12"
woodworkbykirk is offline   Reply With Quote
Crown Molding install question petros151 Carpentry 31 01-14-2012 10:11 AM
crown molding and chair rails hollyjo213 Kitchen & Bath Remodeling 2 10-02-2009 12:56 PM
Matching existing crown molding janralix Carpentry 1 05-11-2009 05:55 AM
Installing Crown Molding in Plaster hoboing Carpentry 8 05-25-2008 07:11 AM
How to cut crown molding spyder9176 Carpentry 11 03-02-2008 09:58 AM
