Basic Studd Wall Building? - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-11-2008, 11:05 AM   #1
Question
Hello.
I'm wanting to frame some inteior 3.5" and 5.5" wood stud walls. I don't have a nail gun so I was thinking of using screws. (I have built walls with nailers before).
My question is when using screws is it required to pre-drill the holes before inserting the screws so the wood doesn't split or can I just drill in the screws?
When using screws can I just replace the required number of nails with screws or can I use less screws?
What screws size/lenght should I buy for framing 3.5" and 5.5" stud framing and is there anything special I will need compared to basic nailing?
Matt
mfleming is offline   Reply With Quote
Old 06-11-2008, 11:40 AM   #2
Registered User
Termite's Avatar
Screws will work fine, and there's no need to pre-drill. The code technically doesn't allow screws however. They don't have the same shear strength as nails do. The minimum code requirement is two 3-1/2" (16d) toenails. Toenails are required because end-grain nailing (or screwing) into the stud has very little strength.
If your wall isn't an exterior wall and isn't load bearing, I'd say use screws.
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 01:39 PM
Building Wall Over Floor bradarth Flooring 2 07-11-2005 10:15 PM
