Basic Deck Rail Design - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-11-2009, 12:00 PM   #1
Basic deck rail design
Hey guys, got a very basic question for a project I am starting to plan out this weekend. I will be replacing the decking and railing on an existing deck.
A couple of question when it comes to railing layout.
1. Is anyone familiar with the maximum spacing for rail posts and ballister in CT? As it's the weekend I don't know where to get code info, but am awar that I must comply with 2005 CT State Building Code which consists of the 2003 International Building Code, 2003 International Existing Building Code, 2003 International Plumbing Code, 2003 International Mechanical Code, 2003 International Energy Conservation Code, 2003 International Residential Code, and 2005 NFPA National Electrical Code with the 2005 CT supplements.
2. My deck is 28 x 14 feet. On one of the 14ft sides there are stairs so it would actually have about 11ft of railing. Would it be aesthetically okay to use one Rail post spacing on the 14ft faces and another on the 28ft length? What about the 2 14ft sides should each of them have a unique spacing?
dram is offline   Reply With Quote
Old 07-12-2009, 07:56 AM   #2
IRC 2006 R311.5.6: Handrails shall be between 34-38" high, seems to refer to interior handrails. R312 refers to porches, balconies, etc, and that height requirement is 36"min. Balusters shall be such that nothing larger than 4" can pass through.
I was not able to find anything on post spacing. Hope this helps.
Old 07-12-2009, 12:27 PM   #3
You also need to check with your local building codes as they are sometime more strict than the IRC. Call your local building inspector's office. Also, don't forget to get any permits needed before you start.
Josh Jaros Remodeling in The Woodlands, Texas www.jarosbros.com
jaros bros. is offline   Reply With Quote
A couple of Deck railing and privacy fence/screen question EightmanVT Building & Construction 9 06-01-2010 09:03 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
warped deck rail posts cakem Carpentry 1 05-09-2009 09:24 AM
Deck Design Ideas philly529 Carpentry 3 04-20-2009 09:34 PM
