Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 08-16-2009, 04:50 PM   #1
Basement Windows
We need to replace our basement windows. They are wood. How do we get the correct dimensions of them?
maryr006 is offline   Reply With Quote
Old 08-16-2009, 05:08 PM   #2
Building codes guy, Mod
thekctermite's Avatar
Basement Windows
You need to take dimensions of the rough opening that the windows themselves go into. That might be a framed opening or a concrete opening, depending on the type of window and where they're situated.
If there is casing on the windows you'll need to remove it in order to measure the rough opening dimensions.
Take that info to your supplier or go online to the window manufacturer you're going to use. They'll have charts for their full product line. See what will fit in your rough openings. Sometimes it is necessary to go custom, but usually not.
The building code is a minimum standard, and merely meeting it instead of exceeding it equates to building your project to the worst standard that the law will allow.
thekctermite is offline   Reply With Quote
Old 08-16-2009, 10:52 PM   #3
Renovation Contractor
Paragon's Avatar
Basement Windows
Maryr,
Excellent advice and right on the money!
I also wanted to mention that even though it shouldn't really be an issue but just to be on the safe side whenever I measure an R.O. or a rough opening I always take 3 measurements the top the middle and the bottom. I will come down 6" and write down my width measurement at that point then I come down to about the middle point of the opening and take a measurement and then go down to about 6" up from the bottom or so and take a measurement and I always use the narrowest measurement for my RO when giving measurements to the supplier. Then I do this for my height as well. This way if there are some sever discrepancies in the RO you make sure that the window isn't going to be too wide or high for the opening.
Also if you are going to be replacing a lot of or even just a few windows and are going to be ordering them from someone they some times come out and measure them for free, if you are purchasing the windows from them. This is more so the case for window suppliers and not the big box stores. The big box stores will come out and measure them but will charge you unless you are going to have THEM install the windows and is sometimes the case with suppliers as well. They usually require you to pay a fee to measure the windows like $50 - $100 and then will refund that if you hire their installers where as the suppliers just charge this and refund it off the purchase price, but you can install those yourself saving you a little money there.
At best if you are going to be replacing and installing the windows yourself you can stop in to your local big box store such as Home Depot and go into their building supply department and they will have measuring "how to" guides right there for you to use. This will give you instructions for measuring for replacement windows however this method will leave you responsible for any errors in measuring so it is up to you whether or not you want to take the responsibility when ordering windows.
Just some food for thought and what I would do is talk to a couple window manufacturers and suppliers in your area and see what works best for you.
Good luck and be safe.
James D. Van Raden
Owner, Paragon Renovations Moorhead, MN/ Fargo, ND
"Committed to providing the finest renovation services available"
Paragon is offline   Reply With Quote
More On This Topic
How to Buy Blinds
How to Buy Blinds by eHow.com
Blinds are a popular window treatment choice because of their durability, affordability and appearance. With so many styles and materials to choose from, buying the right blinds for your home can seem overwhelming. Buying blinds is actually quite simple... Read More »
A GST (goods and services tax) is a sales tax commonly found in Canada, Australia, Hong Kong, New Zealand and Singapore. It is added to the purchase prices of goods and services, although you may be eligible for a GST refund if you are shopping abroad... Read More »
Using full sheets of drywall--also called sheetrock--is recommended whenever possible, but designing a project perfectly around the standard size of a sheet of drywall isn't that easy. So measuring when installing drywall and cutting the sheet to your... Read More »
A VAT (value added tax) is similar to an American sales tax, but it is applied in most European countries to shopping purchases and automatically added into the price. Tourists and any other non-residents are often allowed to receive a 15 to 25 percent... Read More »
Imagine the compliments you will receive when people see your curtains in a fabric that complements your room's design. Imagine the surprise that will come when you share that your new curtains are made from tablecloth. Tablecloth curtains in a rich... Read More »
Choices in Replacing Basement Windows 2031pratt Remodeling 3 06-06-2009 08:00 PM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 01:18 PM
Basement windows in masonry walls dave11 Building & Construction 1 03-20-2009 09:28 PM
Basement windows above floor joists billthecat Building & Construction 7 10-20-2008 09:07 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
