Basement Window Trim - Uneven Sides - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-12-2012, 10:11 AM   #1
Putting some finishing touches on my Basement remodel and had a question about trimming out my windows.
My two small egress windows are right up against a protruding "display wall", and fairly high on the finished wall framing and close to the drop ceiling track. While the picture below is from before the drywall went up, hopefully its enough to give a rough idea. I've already made my jamb extensions.
There is only about an inch of space for trim on the top and side, whereas there is a larger gap on the bottom and opposite side.
My question is what is the best way to trim this window out? I'm thinking having normal wider trim on the bottom/side and have it directly return into the ceiling/display wall. Then on the thinner sides, just rip flat stock.
How would this look, and would there be a better solution?
Setzer1994 is offline   Reply With Quote
Old 11-12-2012, 10:22 AM   #2
Rewards Points: 13,450
Just add shims to the rough framing where there needed so the exposures will all be even.
Simple strips of OSB will work.
Old 11-12-2012, 10:26 AM   #3
I thought about that too, however that would likely require patching some drywall to get the gap smaller on the bottom/side. Up against the "display wall" I really only have about 3/4".
Old 11-12-2012, 09:08 PM   #4
AHH, SPANS!!!
Rewards Points: 1,166
I use the jamb of the window and how much the extension sits onto the jamb as the guide and shim around the outer edges of the extension to the rough framing. let any difference amongst the 4 differing jambs be behind the extensions...
hand drive is offline   Reply With Quote
Window trim over existing T-111? J Howard Remodeling 2 07-24-2012 10:49 AM
Basement Window / Buck Gaps and Leaks ? Carles Windows and Doors 2 07-01-2012 12:06 PM
New basebords and trim are white but all window frames are stained cedar? mibson Interior Decorating 0 01-22-2011 01:27 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
Basement window recessed in foundation Freaka Building & Construction 4 11-09-2008 06:15 PM
