Basement Walls And Insulation - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-22-2009, 10:32 PM   #1
Basement walls and insulation
I am finishimg my basement and have the white insulating blanket on the top half of my walls to the frost line. Do i need to take that off, add the vapor barrier foam only dto the bottom half or don;t add anything and frame over the balanket. If I don't use any additional insulation, do I need a vapor barrier over the studs since I have the white insulating blanket?
Thanks for any input
hodak is offline   Reply With Quote
Old 11-23-2009, 06:29 AM   #2
Remodeling Contractor
please do a search for info on basement finishing. All the info you need has been answered over and over again. If you finish a basement it must be insulated by code. Unless you are in Canada you should not be using a vapor barrier anywhere. The area above ground is treated differently then below grade levels. Read and learn then ask more specific questions. Unless you do this right you will be doing again next year.
Old 11-23-2009, 08:31 PM   #3
Registered User
Rewards Points: 5,516
Welcome to the forum! As Bob said, do a search. I have used this article 4 or 5 times, and haven't been here nearly as long as Bob has: http://www.buildingscience.com/docum...ts?full_view=1 This is just the tip of the iceberg!
Be safe, Gary
Old 11-24-2009, 12:58 AM   #4
basement insulation research
Real good stuff. Good resource
thanks
Insulation of interior walls around fire place ODD Calmeier Building & Construction 5 01-31-2010 05:59 PM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 04:44 PM
Insulation for Concrete Basement Walls soundman79 Building & Construction 8 07-15-2009 01:54 PM
basement insulation and vapour barrier coolnes Remodeling 11 02-01-2009 08:56 AM
Installing insulation and vapor barrier to exterior basement walls Fernando Sinn Building & Construction 11 04-11-2008 11:11 AM
