Basement Storage Door - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-06-2011, 01:25 AM   #1
Not worried about code here or anything, but am planning on putting a door into an unfinished basement storage area. The problem is this area has a soffit that drops the ceiling height to 6'4. My preference with doors would be prehung to install myself, but I don't want to drop the door knob down 7" if there's a better option. And the 7 inches isn't even counting the cripplers that "should" go above the door. So, does anyone have any good suggestions for a door in a 6'4 space? (by the way, I'm counting a 2" jamb, real height is 6'6 but I do want a finished look at least from one side).
Shaotzu is offline   Reply With Quote
Old 04-06-2011, 06:19 AM   #2
Solid core flat door.........can be cut to suit the opening, put the door knob where you want it. A hollow core door can also be cut down, but requires a bit more work to add back the solid piece in the cut end. Raised panel door would require too much cutting and look odd, and a custom door is way too expensive for this door.
Old 04-06-2011, 06:53 AM   #3
Not so new
12penny's Avatar
Rewards Points: 520
....this requires a little more work. Remove the door from the jamb. Cut off the top of the door and fill void. Dissassemble jamb and cut off the tops of the legs to required length. Reassemble jamb and install.
12penny is offline   Reply With Quote
Pre-Hung doors - How to Hang Willie T How To Guides 23 01-28-2011 09:24 AM
Help with Swing out door into Breezeway/garage Brick wall! wad2k Building & Construction 3 04-25-2010 05:45 PM
Entry Door Size han Building & Construction 5 08-20-2009 07:54 AM
Entry Door---My Story----Advice Please rossmoor Building & Construction 3 02-29-2008 09:13 PM
basement door esel Introductions 3 01-21-2007 01:35 PM
