Basement Steps Couple Questions - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-25-2013, 08:04 PM   #16
Indentured Servant
I have it laid out but something is slightly wrong. Haven't cut yet. I think I need to subtract the width of my riser from the very last step up onto the main floor. If I do this everything jives.
jackpine is offline   Reply With Quote
Old 01-25-2013, 08:15 PM   #17
GBrackins's Avatar
Rewards Points: 2,108
one thing I've found that helps to strengthen stringers is to attach a 2x4 along the bottom of the stringer, two on the center stringer. this will typically double (on ends) and triple (on center) the material that is left after cutting the stringer.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 01-25-2013, 08:30 PM   #18
funfool's Avatar
Rewards Points: 534
Is there any advantage to using an LVL product over 2x12?
They are great, will be guaranteed to be straight, in this case, was such a long run we used them for that purpose. They do cost more, but in many cases I feel is worth it,
I called these the step and slide stairs.
Was simply the home owner could not make up mind if they wanted a landing and turn the stairs after the post, or just straight through.
But yeah, is a pleasure working with the LVL and will use them every chance I get.
funfool is offline   Reply With Quote
Old 01-25-2013, 08:33 PM   #19
funfool's Avatar
Rewards Points: 534
oops, was going to attach a pic to that and got tied up and forgot
Old 01-26-2013, 03:56 PM   #20
Indentured Servant
Finally getting back to the project. Should be done in an hour or so.
Basement Finishing Questions lmf232s Remodeling 3 01-20-2012 10:04 PM
Installing radiant heating in a basement and general basement questions... CarlsonRower General DIY Discussions 6 12-09-2011 01:32 AM
Basement Reno Take II...A Couple of Questions monsterbash Building & Construction 3 08-25-2010 10:16 PM
Basement Sump Pump & Dimpled Plastic Membrane Interior Questions cloves Building & Construction 0 03-24-2010 10:44 PM
Basement Return Questions 108Stitches HVAC 5 02-03-2009 11:56 AM
