Basement Stairs - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-04-2016, 11:59 AM   #1
Basement stairs
How do you guys recommend finishing/framing the wall that is tight against the stairs? Thanks!
lpv77 is offline   Reply With Quote
Old 03-04-2016, 01:50 PM   #2
Rewards Points: 1,224
Looks like you need a sheet iron to me.
Paneling is old school , but I would still consider it.
ED
de-nagorg is online now   Reply With Quote
Old 03-04-2016, 02:00 PM   #3
Rewards Points: 805
"Looks like you need a sheet iron to me."
what is a sheet iron?
TimPa is online now   Reply With Quote
Old 03-04-2016, 02:12 PM   #4
Rewards Points: 702
I could provide a couple of pics of mine if you thought it may help. Construction may not be identical and probably isn't on any two sets of stairs but pics may spark an idea.
Old 03-04-2016, 02:19 PM   #5
Would appreciate it. Thank you. I was thinking just using stone veneer or grinding down high spots and gluing drywall to it
Old 03-04-2016, 04:31 PM   #6
Rewards Points: 702
One difference I readily see is the first floor wall on mine is set back about 2" from the inner basement wall. The concrete corner is capped with the on site routed molding with the purchased base board against the bottom plate framing of the upper wall.
These may or may not help but we can always say we tried and good luck with yours.
Old 03-04-2016, 04:41 PM   #7
Rewards Points: 226
Clean up the yack spots and paint it, panel it, attach firring and Sheetrock, whatever. Ron
ront02769 is offline   Reply With Quote
Old 03-04-2016, 05:01 PM   #8
It is a protective sheet of steel plate to keep the walls from being dented / dinged / pierced by objects banging into the wall.
There are several scratches , dents , and marks on the current wall.
ED
Old 03-05-2016, 08:22 PM   #9
Stairguy
Millertyme's Avatar
Rewards Points: 508
Ramset some 3/4 strapping to the wall and drywall it.
Millertyme is offline   Reply With Quote
Old 03-06-2016, 08:46 AM   #10
Rewards Points: 502
PVC panelling glued. Panel trims for the edges and screw. You have space for slipping the panel next to the stringer. Clean the pvc with acetone. Primer for pvc and you can paint it.
carpdad is offline   Reply With Quote
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 07:02 PM
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 09:55 AM
Outside basement stairs, bulkhead stairs, etc anesthes Building & Construction 0 03-29-2011 06:33 AM
Cutting drywall side of basement stairs? Oxymoron Drywall & Plaster 4 10-07-2010 10:13 PM
Basement Stairs/ EZ Stairs mjkpainting Carpentry 8 02-24-2010 10:24 PM
