Basement Stair Support - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-21-2013, 11:09 AM   #1
Basement stair support
Sorry for cross posting in Home Repair, but I didn't know ther was a carpentry board.
I want to replace a small flight of stairs to the basement due to sloping, squeaking and basically nothing holding it up.
The problem is there is no way to extend the total run due to an exterior door at the lower landing and another flight to the basement floor, so the stringers have very little to attach to. The rises and runs are already both near 8 inches so I really don't want to add a hanger board and that wouldn't fix the support for the bottom of the string. The only thing I can think of is to add three 2x6 and run them from the landing joist to blocking behind the top ledger joist. (see attached).
Any better ideas?
beulahsue is offline   Reply With Quote
Old 08-25-2013, 08:33 PM   #2
Haverhill Trade 1965
Looks reasonable. Any room for a post or knee wall under the bottom end?
Duckweather is offline   Reply With Quote
Old 08-26-2013, 07:20 AM   #3
Finished this over the weekend. Ended up cutting about 2 inches off the bottom tip of the 2x6s and attached them to the 2x10 with 2x8 joist hangers. The whole thing is very solid. Thanks for the suggestion.
The Following User Says Thank You to beulahsue For This Useful Post:
mae-ling (08-26-2013)
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 06:02 PM
Drilling through wood support beam in basement Breakingcustom Building & Construction 12 06-16-2012 09:32 PM
Steel support beams on basement wall gmbwrenchn Concrete, Stone & Masonry 4 04-30-2012 09:13 PM
Basement - Removing or moving support post jfgagnon Remodeling 12 08-08-2011 07:11 AM
Need help with basement support jaw522 Building & Construction 3 10-25-2006 08:55 AM
