Basement Stair Rail And Baluster Question - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-04-2012, 04:06 PM   #16
Originally Posted by Millertyme View Post
Oh, and one more thing, if you want to know a super easy way to lay out that post height and notch let me know
I'd love that if you have it, thanks!
Mike, here are some shots from the other side.
agreif is offline   Reply With Quote
Old 08-04-2012, 04:50 PM   #17
Stairguy
Millertyme's Avatar
Rewards Points: 508
On the right side of the stair, draw about 3' of your rail at the correct position. 34" plumb from the nosing to the top of the rail. Now go to the left side and find out where the back of the post will end up in relation to the riser or nosing and transfer this same measurement to the right side drawing. Draw a plumb line on your wall to represent the back side of your post. Start at the top and draw in your squares for you post making sure you center the back square of the post with the center of your rail pitch cut. Draw the bottom square of your post to get the notch height
Millertyme is offline   Reply With Quote
Old 08-17-2012, 12:41 AM   #18
OK guys, got the half lap cut in the newel. What's the best pattern to use to secure the newel with lag bolts? Two vertically in line would be ok, or should I offset them left to right from eachother?
Old 08-17-2012, 06:18 AM   #19
Stairguy
Millertyme's Avatar
Rewards Points: 508
In a vertical line centered on post
Old 08-17-2012, 12:33 PM   #20
Rewards Points: 150
I would offset them since the block your lagging into is about 6 inches, 2 lags on the same grain of a 6 inch block is asking for a wiggle.
Hammer450R is offline   Reply With Quote
Old 08-17-2012, 12:34 PM   #21
Rewards Points: 150
You need to cap it and shim the whole thing flat and plumb first
One more thing...I wouldnt half lap it, i would only remove an inchif your going to lap it at all...you want some meat at the bottom of the post for countersinking of the lags
Old 08-17-2012, 01:05 PM   #22
Ole Wood Worker
BigJim's Avatar
Rewards Points: 116
I always half lapped my posts for that style of stairs like Millertyme and never had the first problem with them.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 08-17-2012, 01:21 PM   #23
Rewards Points: 150
Im just saying if you half lap you end up with 1 3/4"...after countersinking lag hole of at least 3/4-1" for the lag washer and deep enough for a good cap.
Leaves you with 3/4 of actual wood to grab.
Yes it might be enough but i just think more is better, so im sticking to lapping it 1" instead of half lap. But thats just stuff that helps me sleep at night lol
We are only talking 3/4 inch difference between 1 inch and half lap. Doesnt change the look that much. But i agree no lap looks hideous.
Old 08-17-2012, 02:39 PM   #24
Stairguy
Millertyme's Avatar
Rewards Points: 508
there is no need to lag them in either. I use deck screws and construction adhesive. Plug holes with 3/8" plug. Lags are overkill and leave a large hole to cover up later.
A couple of Deck railing and privacy fence/screen question EightmanVT Building & Construction 9 06-01-2010 09:03 PM
