Basement Stair Headroom - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-25-2013, 12:13 PM   #1
Thank you in advance for reading this and your help. Redesigning our basement stairs and need to remove the doubled floor joists that holds up the wall above it for additional stair headroom. A 4x4 post will be added for extra support when removing this section of the doubled floor joist as you come down the stairs, but not sure if there is still enough headroom. Attached are pictures of the job and my dimensions. Does anyone have ideas if we can keep 9" tread and 7.5" rise, and have enough headroom for 2nd to last and last stair? Should we build platform at bottom of stairs, going in a different direction (90 degrees) for bottom 2 stairs?
Basement Stair Headroom-dscn1824.jpg   Basement Stair Headroom-picture..bsmt.jpg
garysacco is offline   Reply With Quote
Old 03-25-2013, 01:23 PM   #2
GBrackins's Avatar
Rewards Points: 2,108
I'd recommend checking with your building official before changing anything. You need to know what the building official is going to require. I'm would think you'd be required to obtain a building permit since you are working on a means of egress. I know in my area a permit would be required.
You also need to verify the local requirement for maximum riser height and minimum tread depth.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
The Following User Says Thank You to GBrackins For This Useful Post:
jaydevries (03-25-2013)
Old 03-25-2013, 07:09 PM   #3
Rewards Points: 654
There is no room for the stairs to become straight down. I think you would need to lose about 2 joist bays and encroach into the room behind that wall. This means headers, posts and footings in the basement and reframing upstairs. You must have 6'8" anywhere from the tread to the ceiling.
carpdad is offline   Reply With Quote
Old 03-25-2013, 07:11 PM   #4
Rewards Points: 636
you are going to need 10 to 12 feet to make that work not 77 inches so that means a lot of floor joist are going to need removed and re supported and say good by to all the floor space on the 1 st floor.
i agree with gb post.
http://www.blocklayer.com/stairs/stairseng.aspx
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 03-25-2013, 07:28 PM   #5
Roofmaster
Rewards Points: 2,172
Sometimes things just ain't worth it. What are you trying to gain?
You may be much better off with a Bilco for basement access if that's what you are trying to achieve.
The Following User Says Thank You to jagans For This Useful Post:
Basement Stair Balusters daveplot Carpentry 2 01-13-2013 05:24 PM
Basement Stair Riser Height Variation w/ Subfloor BSponz1 Building & Construction 3 11-08-2012 06:50 PM
Wet basement - don't know where to start konradsa Building & Construction 17 09-20-2011 10:08 AM
Basement Stair Ceiling Odd ryanb4614 Building & Construction 4 08-20-2011 05:59 AM
basement stair railing nsanto17 Building & Construction 1 03-01-2011 06:14 PM
