Basement Stair Balusters - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-13-2013, 05:29 PM   #1
Rewards Points: 77
In my 1976 home I have a single handrail on my basement stairs which works fine, however, there are no balusters. This is a problem now that my young children need to be going up and down the stairs.
Please take a look at the attached photos. Does anyone have any recomendations for baluster installation?
My thought would be to install a new handrail in line with the newel post to the ceiling at 36", leaving the existing handrail. Then balusters down from it to the stair below. Something like the first photo here, but to each stair: http://www.danielskitchenbath.com/miscphotos.html
daveplot is offline   Reply With Quote
Old 01-13-2013, 06:18 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 180
I didn't build this staircase and the extensions aren't the way I would do them but this will give you and idea how to offset your rail, also here is a picture of the fitting you will need. Check to see what code is for spacing the balusters in your area, most places is 4 inch. To install the balusters drill your holes plumb, put top of the baluster in first, lift up, then put bottom of the baluster over the bottom hole, and slide down into the hole. You can use iron or wood baluster.
If you plan to use the existing post for the Newel you may have to have another newel post on the first step also, it looks like two steps are past the post now.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
joecaption (01-13-2013)
Old 01-13-2013, 06:24 PM   #3
Rewards Points: 13,228
Pain in the butt to do but would work, be legal and look ok.
Going to need a set of Forister bits.
http://www.rockler.com/product.cfm?p...5&site=ROCKLER
Basement Stair Rail and Baluster Question agreif Carpentry 23 08-17-2012 02:39 PM
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 09:55 AM
Wet basement - don't know where to start konradsa Building & Construction 17 09-20-2011 11:08 AM
stair balusters anthonyr Carpentry 5 05-15-2010 10:14 AM
Thoughts and ideas basement finishing and HVAC creamaster HVAC 1 03-10-2010 08:46 PM
