Basement Soffit Help Needed - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-10-2014, 03:46 AM   #1
Rewards Points: 422
Basement soffit help needed
I need to build a soffit to hide a HVAC duct and other pipes. BUT all the pics I see show the 2X lumber running under the ductwork. I want to avoid this to save 1.5" of ceiling height. How can I frame the soffit so the drywall is kept very close to the bottom of duct? A pic or link would be great. Thanks.
Jim McC is offline   Reply With Quote
Old 01-10-2014, 06:50 AM   #2
Not so new
12penny's Avatar
Rewards Points: 520
Steel will save 5/8".
12penny is offline   Reply With Quote
The Following User Says Thank You to 12penny For This Useful Post:
Windows on Wash (01-10-2014)
Old 01-10-2014, 07:15 AM   #3
DIY staff
Rewards Points: 7,174
No pictures for you--but I often build the soffit sides out of 1/2" plywood and 2x2 nailers----when possible---I'll slip one or more in between the ducts/pipes to act as attachments for the drywall---if this can be done--no framing is needed below the ducts at all---so the drywall is right below the ducts---
You will need a really long screw bit extension to attach the plywood/2x2 between the ducts---
Old 01-10-2014, 01:52 PM   #4
Rewards Points: 422
Thanks guys. It's a HVAC rectangular duct that runs the whole length of the 18' room. It's about 20" wide and sticks down about 8". I'd like to build the soffit somehow where there is no framing under the duct, just the drywall like Mike said. I have yet to find any pics though on how to do it.
Old 01-10-2014, 02:22 PM   #5
Soffit Ideas
I am dealing with the exact same situation in my basement so I am looking forward to hearing if or how it can be done.
Could the 2x4 or 2x2 extend down from the joist just enough to clear the duct and then screw the drywall directly to the end of the board?
My area consists of 2 ducts and a beam that need to be wrapped. They all hang down about 9 inches from the floor joist similiar to the OP. I would hate to lose much more headroom in that area.
Rooki is offline   Reply With Quote
Old 01-10-2014, 07:49 PM   #6
Rewards Points: 422
That's what I'd like to do. Have you found any pics of this method?
Is there a maximum width that the duct can be to use this method(unsupported drywall)?
Old 01-10-2014, 09:28 PM   #7
chitownken's Avatar
Rewards Points: 510
You should be able to span up to 24" if you use 5/8 drywall.
chitownken is offline   Reply With Quote
Old 01-13-2014, 01:10 AM   #8
Rewards Points: 422
When building 2 soffits perpendicular to each other, what determines which one is built first? Does ceiling joist direction have anything to do with it? Thanks.
Old 01-13-2014, 06:32 AM   #9
DIY staff
You will build which ever one is easiest first--that's human nature---it makes no real difference which is built first---
Old 01-13-2014, 12:21 PM   #10
Rewards Points: 422
Thanks. When boxing in basement HVAC ductwork, do I need to use moisture resistant drywall? I read that somewhere, but it seems odd.
Basement Renovation: To soffit or not to Soffit ppeetteerr Remodeling 8 10-18-2012 09:43 PM
Slim Soffit for Ductwork in Basement stubits Building & Construction 4 04-28-2010 03:48 PM
45 degree basement soffit / triangular soffit PNOTY96 Carpentry 3 09-11-2009 01:48 PM
pre-stubbed basement bath vent needed? ameleus Plumbing 7 09-21-2008 11:26 AM
soffit in basement DIY4EVER Building & Construction 2 06-18-2007 10:05 AM
