Basement Slider Header - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-04-2008, 06:49 PM   #1
Question
I want to replace a Basement slider, I have one floor above plus roof. The new door I have is 81.5" and opening is 80.5. There is currently 2 2x10's for header. I need that additional room. since the door is 6 ft. wide, I heard I can replace those 10's with 2 2x6 and be safe? Anyone know if thats OK? and if not is there any other way since the bottom is on concrete footer..
rayst is offline   Reply With Quote
Old 05-04-2008, 11:58 PM   #2
Registered User
Termite's Avatar
With the load of the floor above and the roof, an opening of that width typically requires two 2x10's. The deflection that you'd experience with two 2x6's would probably affect the function of the door, not to mention it would be structurally unsafe!
Whoever told you that you could use 2x6's gave you some bad advice.
The only way I could see you getting away with two 2x6's is if you were to bolt a 1/2" steel flitch plate between them.
Old 05-05-2008, 09:18 AM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Why not investigate a 4 by 8 inch glue lam beam. That will give you the 2 extra inches you need.
rjniles is offline   Reply With Quote
Old 05-05-2008, 10:22 AM   #4
Home Remodeler
Rewards Points: 164
Buy the correct size slider.
mikey48 is offline   Reply With Quote
Insulate basement header with imbedded joists??? lackofunds General DIY Discussions 21 04-17-2011 04:41 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 12:07 PM
Sub Basement Walkout - Please Help pgs_28 Building & Construction 11 08-12-2007 10:55 PM
Moving Header Supports Star Building & Construction 3 09-25-2005 01:50 AM
