Basement Repair - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-04-2011, 11:02 PM   #1
basement repair
looking at purchasing a house that had 8 inches of water..long enough for white mold to appear...they vacuumed the water out, fixed the sump pump, pulled out the flooring and ran a new dehumidifier but did nothing for the molded drywalls...question: there are several rooms of walls..is there any way of salvaging the drywall/paneling? If I need to remove, can I leave the framing? Any comments would be appreciated. thanx in advance. julie
jshotwell is offline   Reply With Quote
Old 09-05-2011, 08:18 AM   #2
DIY staff
Rewards Points: 7,174
Get a SawsAll---snap a chalk line 4 foot off the floor and remove the bottom section of drywall--
If they left the walls wet (and it sounds like they did) you will want to clean out the bottom--inspect the framing and clean with bleach---replace any insulation--and then replace the drywall and trims.
Old 09-05-2011, 11:44 PM   #3
Registered User
Rewards Points: 4,912
Good advice from Mike, if I might add….
Take safety precautions for your health; http://www.toxic-black-mold-info.com/moldclean.htm
Wood is organic and neutralizes common household bleach; try a product specifically for wood; http://www.toxic-black-mold-info.com/disinfectant.htm
Bleach on hard surfaces only, not wood grain; http://www.spore-tech.com/viewCatego...?idCategory=78
Replace the insulation: http://www.inspectapedia.com/sickhou...rglassMold.htm
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
oh'mike (09-06-2011)
Old 09-08-2011, 09:22 AM   #4
If you need some more info pm me,
while some info on here is good, some other info is bad. I work in the insurance industry and we perform some mold cleanups on daily basis. If you don't take the right precautions, mold and other problems will be back within few month.
laflsyl10 is offline   Reply With Quote
Old 09-08-2011, 12:26 PM   #5
Registered User
The whole idea of a forum is to get different opinions on solutions. Without explaining why some or which are good or bad is interesting, to say the least. Please explain as a PM is just that, others will not benefit. We won't bite your head off..... lol.
Gary
Best Way to Dehumidify Basement? ntauctions HVAC 9 05-31-2013 02:36 PM
Remodeling basement: Moist foundation gordonf238 Building & Construction 8 04-25-2010 07:50 PM
Basement concrete floor repair estimate ControlTech Building & Construction 1 04-10-2010 08:28 AM
Basement Renovation Project Howdy Electrical 6 03-13-2008 12:07 PM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 10:09 AM
