Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 08-18-2011, 05:52 PM   #1
basement partition wall - framing question
I'm adding a partition wall in the basement. It will be directly under a laminated beam, which is supported by lolly columns; the wall will enclose the columns. So the wall is not structural, just a divider.
Question: to meet code, do I need a top plate under the beam or can I nail the 2x4s directly to the underside of the laminated beam?
(I'[ve already done a small part of the wall and hope I don't have to start over.)
Ray
RCharles is offline   Reply With Quote
Old 08-18-2011, 09:03 PM   #2
Framer
Nope.. The only reason you need a double top plate is for carrying load from above and fire break..
If you are building a non load bearing wall you don't need any plate under the beam because the beam carries its own load and it is a fire break..
But, If it was my house, I'd put a plate under the beam.. lol but that is just how I frame
good luck
joeyr is offline   Reply With Quote
Old 08-18-2011, 09:08 PM   #3
you need a plate for drywall nailing....as if?
Marbledust is offline   Reply With Quote
Old 08-18-2011, 09:19 PM   #4
Framer
Pretty sure the beam would be sufficiant to hold the drywall as it is the top plate
Tags
framing, top plate
Basement framing - drywall ceiling question tmhouse Building & Construction 1 07-11-2011 01:11 PM
Basement wall framing tsperry Building & Construction 2 04-23-2011 11:58 PM
Framing basement wall without covering top plate and rim joist dave11 Building & Construction 5 10-30-2009 09:38 PM
Exterior wall framing question Pmatyj01 Carpentry 5 10-04-2009 02:09 PM
Loads on a partition wall acyate Building & Construction 8 03-01-2009 12:02 AM
