-   -   basement partition wall - framing question (http://www.diychatroom.com/f14/basement-partition-wall-framing-question-114525/)
RCharles 08-18-2011 04:52 PM
I'm adding a partition wall in the basement. It will be directly under a laminated beam, which is supported by lolly columns; the wall will enclose the columns. So the wall is not structural, just a divider.
Question: to meet code, do I need a top plate under the beam or can I nail the 2x4s directly to the underside of the laminated beam?
(I'[ve already done a small part of the wall and hope I don't have to start over.)
Ray
joeyr 08-18-2011 08:03 PM
Nope.. The only reason you need a double top plate is for carrying load from above and fire break..
If you are building a non load bearing wall you don't need any plate under the beam because the beam carries its own load and it is a fire break..
But, If it was my house, I'd put a plate under the beam.. lol but that is just how I frame :yes:
good luck
Marbledust 08-18-2011 08:08 PM
you need a plate for drywall nailing....as if?
joeyr 08-18-2011 08:19 PM
Pretty sure the beam would be sufficiant to hold the drywall as it is the top plate :laughing:
