Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 06-06-2011, 10:36 AM   #1
Send a message via Skype™ to navaidstech
Question
Basement handrails in Ontario - help!
Guys.... I need someone in Ontario to explain the issue of handrails on basement staircases.
I've read the Ontario Building Code and don't have the cash to hire a lawyer and have him translate it into English.
Here is the issue (see attached pic) : solid wall on one side, open on the other. The code suggests (I think) that if the width of my stairs is less than 1100 mm (43") in width, then I only need a handrail on one side. My stairs are 30 inches in width, well below the limit.
I guess the questions here are: am I interpreting the code right? If so then I could easily install the handrail on the solid wall and call it a day (which would make my life that much easier which in Ontario is a rarity these days)
Any info would be greatly appreciated.
Alex
navaidstech is offline   Reply With Quote
Old 06-06-2011, 12:16 PM   #2
STAFF
BigJim's Avatar
I am not in Ontario but you are interpreting the code wrong, you will need a rail on the open side as a child could easily fall from that side. You can inexpensively make a rail system which will look good using 2X2s and a heavier piece of lumber for the rail. The 2X2s can be profiled in several different ways to look good.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is offline   Reply With Quote
Old 06-06-2011, 12:55 PM   #3
Yeah... that's what I figured. But it's always better to ask just to be sure.
I guess the toughest part would be finding 2x2's that are not warped.
Thank you for the suggestion.
Old 06-07-2011, 10:16 PM   #4
I'm in Ontario, but haven't been involved with building a stair or hand-rails.
However, I just finished a deck and the code required a hand rail with ballasters close enough, that a sphere, 4" in diameter cannot pass through. This applies to decks 24" or more above grade.
I doubt that interior requirements would be less stringent than this.
Old 06-07-2011, 10:23 PM   #5
My daughter had a deck built and she didn't want the view blocked by the ballasters.
The carpenter installed 1/2" rebar for ballasters. He drilled holes in the top and bottom rails to mount the rebar.
Another option would be to use 1/2" electrical metalic tubing. (EMT)
Old 06-08-2011, 11:05 AM   #6
Wildie... I was at Home Depot yesterday and I almost had the same idea, but use black tubing instead. All I would need is top and bottom rails for the opening and voila!
Unfortunately, when I presented the idea to my wife, she quickly shut it down claiming that it will look like a jail cell.
I really don't give a rats rectum what it looks like. I'm just trying to ready the house for the market so the home inspector won't have anything to complain about. I'll see if I can talk some sense into her...
I think jiju1943's would work too but I think 2x2's are too thin for this application. I believe Ontario requires the thickness to be at least 1 3/4" when using softwood and 2x2's are only 1 1/2...
Thanks!
Old 06-08-2011, 02:51 PM   #7
Thanks!
Buy your wife an orange jump suit, then the bars would fit right in.
Old 06-08-2011, 04:45 PM   #8
concretemasonry's Avatar
Make it right from both an appearance and safety standpoint. That will satisfy yhe home inspectors (they are well drilled on the safety aspects) and the buyer that won't bother with a offer or and inspection in the first place. - Especially in an orage suit.
Dick
concretemasonry is offline   Reply With Quote
Old 09-25-2011, 11:09 PM   #9
Well guys...thank you for all your advice. Here is the finished product.
This doesn't fully adhere to the code as the handrail is supposed to run from the top of the stairs all the way to the bottom but I'll cross that bridge when I get to it. At least the opening has been covered up.
Old 09-26-2011, 08:29 AM   #10
MikeKy55's Avatar
Looks good!
MikeKy55 is offline   Reply With Quote
The Following User Says Thank You to MikeKy55 For This Useful Post:
navaidstech (09-26-2011)
Old 09-26-2011, 09:39 AM   #11
Nice hand rail.
CJIII is offline   Reply With Quote
The Following User Says Thank You to CJIII For This Useful Post:
Old 09-26-2011, 10:34 AM   #12
Super Moderator
I believe you will also need a continuous handrail on the wall----code ---
oh'mike is online now   Reply With Quote
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
BigJim (09-26-2011), navaidstech (09-26-2011)
Old 09-26-2011, 01:09 PM   #13
STAFF
BigJim's Avatar
That does look good, now all you need is a short wall rail on the wall the open rail is on like Mike said.
Jim
Old 09-26-2011, 07:30 PM   #14
Thanks guys!
I appreciate the compliments.
My wife hates the idea of the rail on the other side so I'll install one just before the house goes on the market so it adheres to code.
The Following User Says Thank You to navaidstech For This Useful Post:
oh'mike (09-26-2011)
Tags
basement, railing, stairs
basement causing suction on basment door BlueBSH HVAC 3 06-08-2010 03:26 PM
Remodeling basement: Moist foundation gordonf238 Building & Construction 8 04-25-2010 07:50 PM
Do I need to waterproof my basement if I already have a french drain? buratti Building & Construction 4 03-20-2010 04:32 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 12:07 PM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 10:09 AM
