Originally Posted by ClemS
you don't need to frame the walls all the way up. and you don't need to rock all the way up.
code says you have to use PT plates on concrete. concrete has no adverse effect on wood. if your basement is dry, don't bother it's a total waste.
Without framing the walls all the way up they will not be bearing against the top joists
That top part provides a lot of support when someone leans against the wall
PT is required by code based on years of experience with building
Water vapor comes thru concrete...even in a dry basement
Not doing it to code & spending the few extra $'s is just stupid
I'd use the PT bottom plate, & a double top plate with 1/2" plywood sandwiched in between
That gets you to 8' 5" which you say you need
Double top & bottom = 8' 6" which is 1/2" too much
Walls should be out 1-2" from the concrete wall, studs should not be against the wall
Best way seems to be rigid insulation against the wall, then stud wall w/insulation
My additon walls are 8' 4.5" tall, the bottom 4.5" will be partly covered by the flooring & rest covered by baseboard
