Basement Framing - Carpentry - DIY Chatroom Home Improvement Forum
Old 10-01-2011, 07:14 PM   #1
Basement framing
When framing a basement what should I install in the corners so I have somewhere to screw the drywall to?
Kastern is offline   Reply With Quote
Old 10-01-2011, 07:21 PM   #2
Rewards Points: 558
like this
epson is offline   Reply With Quote
Old 10-01-2011, 07:57 PM   #3
Cool thank you. Helpful. I had 1x6's that yeas going to screw.
Old 10-02-2011, 07:44 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,202
several methods can be used.. you can can install a L-stud using a 2x6 which will catch the joining g wall and create backing on the opposite side of teh wall
. another method is to use up scraps and block between the studs where the joining wall meets.. putting blockin at 0' 2', 4' 6' 8' ,
or frame the wall the way its done for steel stud, frame the first wall sheet it, then build the next wall . this method is more designed for achieving proper fire ratings for commercial construction but still holds the wall
woodworkbykirk is online now   Reply With Quote
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 07:40 AM
Insulate split framed/poured basement wall, prior to framing... pasichnyk Building & Construction 9 12-20-2010 05:32 PM
framing basement walls nickm1024cobra Remodeling 1 11-08-2010 12:06 AM
Suggestion for framing around ducts/pipe in basement xuc318 Building & Construction 2 12-19-2009 06:07 AM
Framing basement wall without covering top plate and rim joist dave11 Building & Construction 5 10-30-2009 08:38 PM
