Basement Finishing. - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-24-2011, 02:52 PM   #1
Basement Finishing.
How do I frame around an exterior basement french door to finish the basement walls when the existing door is recessed about 2" already in the poured concrete walls?
Bob22485 is offline   Reply With Quote
Old 03-24-2011, 04:30 PM   #2
Picture Please.
pjordan4477 is offline   Reply With Quote
Old 03-24-2011, 05:56 PM   #3
DIY staff
Rewards Points: 7,174
Yep---Picture (or a much better description)--Mike--
Old 03-24-2011, 06:10 PM   #4
Stay-at-home GC
Sounds like maybe a jamb extension situation
One-by pine framing extending from drywall to existing door frame then install casing around the pine as per usual.
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
Finishing a cement basement floor with carpet and tile - no subfloor? vseven Flooring 2 09-21-2010 10:41 AM
Finishing basement - insulation problem? Gooter Building & Construction 6 08-24-2009 09:23 AM
A few Q's on Finishing My Basement - Is there a FAQ on this? ossrocks Remodeling 6 01-07-2009 01:21 PM
Finishing basement - low ceilings alyuka Remodeling 1 01-05-2009 09:13 PM
finishing a basement jimmyfloyd Building & Construction 2 10-21-2008 01:30 PM
