Basement Finishing - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-31-2013, 05:52 PM   #1
Basement finishing
I'm about to finish my basement and I had a few thoughts about it. I was thinking I'd use foam panels in between the studs as insulation, and a plastic sheet vapor barrier. On the floor I thought I'd use a paint type sealant. Does anyone have suggestions on this stuff, whether products, procedures, or whatever else? I would appreciate it.
sgjordan is offline   Reply With Quote
Old 03-31-2013, 09:08 PM   #2
Rewards Points: 150
What climate are you in, that is, where are you located?
TheCamper is offline   Reply With Quote
Old 03-31-2013, 10:56 PM   #3
Mid Michigan. I've had the basement waterproofed. They did it a different kinda way where they pretty much let the water into a weep system in the floor. So I'm not worried so much about water so much as moisture.
Old 04-01-2013, 09:59 AM   #4
Roofmaster
Rewards Points: 2,210
I would not use any type of foam plastic insulation where fire can get to it. The fumes that burning foam gives off are extremely toxic. You already have a vapor barrier on your basement walls with the waterproofing. Not sure if another retarder is a good idea.
Sounds like you really have a water managed system, not water proof.
Old 04-01-2013, 11:26 AM   #5
"You can do anything"-Mom
brockmiera's Avatar
1) Rigid foam on the walls to keep the warm air from coming in contact with the cold concrete walls.
2) Frame walls tight against the foam. Foam is your vapor barrier.
3) spray foam seal top and bottom of the rigid foam
4) use pressure treated bottom plate and sill gasket
5) Batt insulation into framed wall
brockmiera is offline   Reply With Quote
Existing Basement Lights - Finishing Basement bergsj Electrical 6 01-04-2013 02:38 PM
Finishing my basement myself and have some questions boat21 Remodeling 2 09-20-2012 02:13 PM
Finishing a cement basement floor with carpet and tile - no subfloor? vseven Flooring 2 09-21-2010 09:41 AM
A few Q's on Finishing My Basement - Is there a FAQ on this? ossrocks Remodeling 6 01-07-2009 12:21 PM
finishing a basement jimmyfloyd Building & Construction 2 10-21-2008 12:30 PM
