Basement Construction - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-29-2009, 11:42 PM   #1
Hi there guys,
Just wanted to ask if you could possibly point me towards the right direction of a step-by-step basement construction. It's a uni project, though I really don't know where to start. Any help would be lovely.
Sorry if it's alittle blunt
Jamie
Jamie_K is offline   Reply With Quote
Old 03-30-2009, 05:54 AM   #2
General Contractor
joasis's Avatar
I don't know what a "uni" project might be, so more information would be needed.
Basements are not what I would consider DIY projects, but.....depending on a lot of factors and design, maybe.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
joasis is offline   Reply With Quote
Old 03-30-2009, 06:52 AM   #3
Remodeling Contractor
First understand the intricacies of moisture control. Read the articles on www.buildingscience.com first.
Old 03-30-2009, 11:31 AM   #4
Rewards Points: 1,910
1. Dig
2. Erect footing forms
3. Install footing rebar and CEE
4. Pour Concrete footers
5. Remove forms
6. Install wall forms and rebar, brace
7. Pour wall
8. Remove wall forms
9. Rough in underslab plumbing.
10. Place rock, poly and insulation on floor
11. Place floor slab reinforcement
12. Pour concrete floor, cut control joints
13. Apply waterproofing to exterior
14. Install perimeter drain system
15. Backfill
Old 03-31-2009, 03:22 AM   #5
Hi guys.
Well, it's just a site that requires the construction/report on how to 'build' a basement, which will be used for storage and a carpark. Though those point forms help Jogr, thanks!
I just need the know all the required steps that I would have to look into in havin a step by step, like I will follow those point forms, but I need other little things such as a stairs and ramps for wheelchair access.
So for example, just need to know which steps, for example, waterproofing or insulation or slabbing, I'd have to start first.
Thanks fellas :D
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 08:51 PM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 10:52 PM
Hole in new construction basement wall AprilQ Building & Construction 5 07-08-2008 06:14 PM
