Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 03-23-2011, 02:46 PM   #1
Basement baseplates
Can I glue down a treated baseplate in a basement? Or must it be screwed down?
Also, how long should they dry before installing?
Thanks.
Pat
koolie is offline   Reply With Quote
Old 03-23-2011, 02:51 PM   #2
Experienced
Jackofall1's Avatar
Basement baseplates
Hello Pat, welcome the best DIY'r site on the web.
When you say baseplates what exactly are you referring to? the lower horizontal member of a wall?
If a wall, a few screws are advisable, and the wood should be PT
Mark
Old 03-23-2011, 03:04 PM   #3
Basement baseplates
Yes, the lower horizontal board of a wall. It is pressure treated.
Old 03-23-2011, 06:25 PM   #4
Basement baseplates
Ramset -
Old 03-23-2011, 06:46 PM   #5
Basement baseplates
Ramset???
Old 03-23-2011, 07:04 PM   #6
Experienced
Jackofall1's Avatar
Basement baseplates
Originally Posted by koolie View Post
Ramset???
Ramset = 22 caliber shell driving a cement nail.
Old 03-24-2011, 01:05 AM   #7
Moderator
Basement baseplates
With a sill sealer under it; http://www.greenbuildingadvisor.com/...-building-code
And foam board behind it -if exterior wall, no air space. Airtight Drywall Approach; http://www.buildingscience.com/docum...wall-approach/
Foam board rim joist, etc....
Gary
Gary
Clothes taking longer to dry?
basement causing suction on basment door BlueBSH HVAC 3 06-08-2010 03:26 PM
Basement Cooling BTU requirements? neilt HVAC 5 05-29-2010 04:26 AM
Remodeling basement: Moist foundation gordonf238 Building & Construction 8 04-25-2010 07:50 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 12:07 PM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 10:09 AM
