Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 09-28-2011, 06:57 AM   #1
Question
Basement with 8 foot ceilings with a Tray
Hello-
I really need some help here. We are currently finishing off our lower level in our 4 year old home and the number one big mistake I made was putting 8 foot ceilings in our basement. Our basement area is very open but has 2 large beams (12 inch high) that run perpendicular to each other which defines 3 areas. One being a rec room (wet bar and pool table) Second (home theater) and Thirdly (rec area for card table and gaming/sitting area). Walls are framed and would like to put in a tray ceiling to give it a nice look and try to make it appear taller.
My plan was to go 6" down which is half of the support beam height and go 11" out from the wall to create a trey. Do you think this is okay to do or would it make the basement feel more cramped due to to the ceiling height? I know that taller the better is great for tray ceiling. Just never seen one with 8 foot. Your help and advice would be greatly appreciated.
jawhe is offline   Reply With Quote
Old 09-28-2011, 08:16 AM   #2
How high will the ceilings be if you max them out? Can you just make soffits around the beams? What's the height of the beams? My house has 8 foot ceilings and it doesn't bother me at all. My basement has 9 foot ceilings and I don't really notice a difference.
mikegp is offline   Reply With Quote
Old 09-28-2011, 10:17 AM   #3
Hi Mike-
Ceiling height is set in stone at 8'. I would have to go down to build a so called tray. After doing some research it sounds like a true tray ceiling is when it's built up. Anyway, The beams are supports for the upper floor and they are 12" which is 7' from the floor. My concern is that we don't want to feel confined. We have 9' upstairs and I find it a big difference going to my basement at 8 ft.
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 35 10-28-2010 03:01 AM
Adding Subpanel for Basement - Few Questions mindle Electrical 28 01-07-2010 09:49 AM
Finishing basement - low ceilings alyuka Remodeling 1 01-05-2009 09:13 PM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 10:09 AM
Sub Basement Walkout - Please Help pgs_28 Building & Construction 11 08-12-2007 10:55 PM
