Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 01-11-2009, 06:03 PM   #1
basemeant remod
when framing the walls on a basement the way i was taught 1) vis queen or vapor barrier 2) studs 3) insul 4) Sheetrock . i was just told now it is studs,insul,vapor barrier then rock which one is correct ??? thank you
all vinyl is offline   Reply With Quote
Old 01-11-2009, 06:45 PM   #2
basemeant remod
I would call your local inspector and ask what he wants to see. I've seen inspectors say plastic on the foundation wall, plastic behind the drywall over the insulation (normal way), or no vapor barrier at all.
Some advice you receive on the internet can be worth exactly what you paid for it - be careful.
stubborn1 is offline   Reply With Quote
Old 01-11-2009, 09:50 PM   #3
Moderator
Termite's Avatar
basemeant remod
Calling the inspector isn't a bad idea to determine local requirements.
Personally, I wouldn't even consider putting plastic in the wall. That was a great idea in the 1980's and 90's and today a lot of people are finding fault in that method. If you're insulating the wall, the kraft paper facing on the insulation is an effective vapor barrier. Letting the wall breathe isn't a bad idea and can help reduce mold-related issues and an impermeable membrane like plastic can lead to mold.
Old 01-12-2009, 08:04 PM   #4
What can I find here?
Winchester's Avatar
basemeant remod
Newer methods show 2" rigid foam, stud wall, and then sheetrock.
Winchester is offline   Reply With Quote
Remod Questions Webs Remodeling 3 05-13-2006 12:27 PM
