Baseboards Without Nails? - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-07-2014, 01:32 PM   #1
Baseboards without nails?
I have a rather unique situation in my basement. The bottom section of the wall is drywall glued on to solid foam glued on to the cement wall. The foam looks to be about 1" thick. Everything is is good shape and no moisture problems at all.
I know I could glue the baseboards on to the wall, but every so often we need to pull up the laminate floor. Is there any sort of clip system that exists that would allow for the trim to be removable but still look halfway decent?
locus123 is offline   Reply With Quote
Old 03-07-2014, 02:07 PM   #2
Rewards Points: 14,000
Got a lose, lose situation there.
Wall was built wrong and laminate never should have been used.
Why does the laminate need to keep coming out? Water damage?
Old 03-07-2014, 03:13 PM   #3
It's not the whole wall that's like that. It's where it was benched from when they dug out the basement. I imagine the previous owner didn't want to lose a 2x4 or 2x3 depth since this basement is SMALL. Above the bench it's built the way it should with studs and spray foam and drywall.
In the 5 years we've lived here there have been some minor leaks twice. Once when the whole city flooded, and once during another massive flash storm (both considered "75 year" occurrences). Otherwise, it's dry as a bone.
The laminate is actually perfect since it comes out so easily. It's off the floor due to the membrane, and just clicks apart and back together.
Old 03-07-2014, 04:38 PM   #4
Jb1234's Avatar
Rewards Points: 87
Situation is certainly not ideal how it was built but that not your question. How about some industrial double stick tape? Or just use a few dabs of a lower sticking caulk and you could then just pop it off. It'll take some paper with it but not like this'll happen often. But once/if you get real water coming in, that laminate will be toast.
Jb1234 is offline   Reply With Quote
Old 03-07-2014, 05:03 PM   #5
Rewards Points: 276
You could always screw in the baseboard with some tapcons screws that will go through the drywall and insulation into foundation. If it was me I would just glue it like jb said
JustinK is offline   Reply With Quote
Old 03-17-2014, 07:33 PM   #6
Handyman
brucem609's Avatar
Rewards Points: 79
Here is an off the wall answer, for some-taking the baseboard off the wall question:
What about Velcro? You could run a full length the whole length of the baseboard, making sure you use the glue Velcro. If you get regular Velcro make sure you use the 3m tape
This is an easy off, easy on solution
Sent from my iPad using DIY Forum
brucem609 is offline   Reply With Quote
Old 03-18-2014, 12:53 PM   #7
iminaquagmire's Avatar
Rewards Points: 338
Velcro would work and be the easy remove option but not cheap. If you glue it and ever have to remove the baseboard, run a knife along the top edge of the baseboard to cut through the paper so it doesn't tear when the base is pulled off.
iminaquagmire is offline   Reply With Quote
Nails? Nails? Nails?! gunns General DIY Discussions 18 03-06-2014 11:25 AM
Baseboards, molding...corners and nails.. beachfront71 Painting 12 04-06-2013 07:48 PM
Me ranting about nails... Pittsville Building & Construction 14 10-05-2012 12:26 PM
Mahogany Door Jamb - What nails and where? Toronto Carpentry 25 07-26-2012 07:08 PM
33 vs 35 Nails Dilemma banzaitoyota Tools 1 12-28-2010 06:44 AM
