Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 09-12-2011, 08:00 PM   #16
Moderator
kwikfishron's Avatar
Baseboards Outside Corners
Originally Posted by m1951mm View Post
I sent my check for renewal, you did not get it.
Thanks, I will try backing out the top screw and see what I get in the morning. If not I do have really good spackle, caulk and sandpaper.
Ya, I got the check. I’ll send it back if you buy a compressor and a finish gun. Your next job may be stain grade and the screws just won’t cut it.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is offline   Reply With Quote
Old 09-12-2011, 08:06 PM   #17
Tileguy
Bud Cline's Avatar
Could have used cement board screws and called it eclectic.
Old 09-13-2011, 03:16 AM   #18
If you want accurate work for out of square corners a sliding bevel, protractor will give you the angles you need.
chrisBC is offline   Reply With Quote
Old 09-13-2011, 04:05 AM   #19
m1951mm's Avatar
I already have a compressor and three different guns. I really would rather have the dues paid up, need the girly wiggle room.
Mickey
Fantasy Walls and Windows
m1951mm is offline   Reply With Quote
Old 09-13-2011, 11:11 AM   #20
STAFF
BigJim's Avatar
If you take that face piece off you can flatten the wall board a little at the bottom with your hammer and the board will fit perfect. If you want to cut the piece to fit, place the base flat against the back of your saw and lift the end of the base, not being cut, up a little. It is a hit and miss so you may have to try a couple of times, not very scientific but it works.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
m1951mm (09-15-2011)
Baseboards, molding...corners and nails.. beachfront71 Painting 12 04-06-2013 08:48 PM
Curved corners where drywall meets? SouthGAreno Remodeling 12 01-17-2013 04:10 PM
Baseboards around Rounded Corners hgiljr Carpentry 13 09-10-2012 07:08 PM
Should new baseboards go on top of carpet? hawks81 Flooring 4 08-23-2010 12:25 PM
Masking off baseboards 2 PaintedSurface Painting 1 01-18-2010 05:30 AM
