Baseboards - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-05-2011, 03:27 PM   #1
Baseboards
We are installing baseboards in a bedroom. Do you wrap baseboards on the returns in the closet if you are installing closet doors?
Dutchjp is offline   Reply With Quote
Old 03-05-2011, 08:09 PM   #2
Rewards Points: 5,336
You don't install the molding on the door jambs.
I don't know what you're calling, "returns".
Ron
Old 03-19-2011, 01:03 AM   #3
I assume
you want to take the baseboard to the 2*4 that makes up the interior of the opening box with a bi fold type door.
I have seen it where they wrap the corner in front and the corner into the actual closet with a notch in the swing area.
Mid Mo
Mid Mo is offline   Reply With Quote
Old 03-19-2011, 10:01 PM   #4
remodeling pro
The base should be installed after the doors are hung and trimmed out, allowing the base to butt into the side of the door casings. If the interior casing fits tight to the side wall, as is sometimes the case inside a closet, then just run the base into the face of the casing.
Not clear on what you are referring to as "returns" either.
troubleseeker is offline   Reply With Quote
Baseboards before or after skimcoat? BagOfMostlyWate Drywall & Plaster 5 10-23-2010 09:43 AM
Should new baseboards go on top of carpet? hawks81 Flooring 4 08-23-2010 12:25 PM
Masking off baseboards 2 PaintedSurface Painting 1 01-18-2010 05:30 AM
Help removing baseboards without damaging sheetrock Lighthearted Painting 3 04-05-2009 06:52 PM
Click lock floors under baseboards ? bcarwell Flooring 4 03-31-2008 12:03 AM
