-   -   Baseboards (http://www.diychatroom.com/f14/baseboards-97334/)
Dutchjp 03-05-2011 02:27 PM
Baseboards
We are installing baseboards in a bedroom. Do you wrap baseboards on the returns in the closet if you are installing closet doors?
Ron6519 03-05-2011 07:09 PM
You don't install the molding on the door jambs.
I don't know what you're calling, "returns".
Ron
Mid Mo 03-19-2011 12:03 AM
I assume
you want to take the baseboard to the 2*4 that makes up the interior of the opening box with a bi fold type door.
I have seen it where they wrap the corner in front and the corner into the actual closet with a notch in the swing area.
Mid Mo
troubleseeker 03-19-2011 09:01 PM
The base should be installed after the doors are hung and trimmed out, allowing the base to butt into the side of the door casings. If the interior casing fits tight to the side wall, as is sometimes the case inside a closet, then just run the base into the face of the casing.
Not clear on what you are referring to as "returns" either.
