Baseboards - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-24-2007, 08:27 PM   #1
Baseboards
Im in the midst of painting projects. Rather then all that taping and frustration with basebards, do these come off/go on easily so I can paint these different colors easily?
usaalways is offline   Reply With Quote
Old 06-25-2007, 05:28 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Do they come off easy? That is a relative question. They do come off relatively easy. We usually cut the caulking and pry them off with a casing pry bar while using material to protect the drywall. However, why we have taken them off, has never been for painting purposes tho.
The issues that come from removal, paint, and re-install are:
1.) The drywall can get damaged (dented, ripped, marred).
2.) The baseboard can split or get dented or marred.
After removal and painting, and re-installation;
3.) The baseboard can and usually will get scuffed and marred.
4.) You will have new nail holes (from re-installing) that you will need to putty, prime and repaint over.
So, my advice is to just paint while on the wall. It's the pro way it's done in such circumstances (when the B.B. is already on the walls) ...
- Build Well -
Old 06-25-2007, 07:08 AM   #3
Old School
cabinetman's Avatar
So, my advise is to just paint while on the wall. It's the pro way it's done in such circumstances (when the B.B. is already on the walls) ...
I agree with all of that. You covered it pretty good. I'd like to add that moulding like that never seems to come off cleanly without damage, or go back in place very well. If it is a case of removal, I just trash the stuff, and don't try to save it. It isn't worth the time and effort to prep old moulding.
If the project is just to change color, or freshen up what's there, having it in place, and touching up holes, dings scratches and ill fitting joints will improve it beyond the condition it already is in, while putting on fresh color.
cabinetman is offline   Reply With Quote
spray or brush baseboards? mathdan Painting 20 06-05-2015 09:41 PM
blackening on carpet around baseboards ejlog Flooring 12 07-09-2008 09:49 PM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 07:48 PM
Colonial Moldings, casings, baseboards sootybuttercup Carpentry 3 10-06-2006 05:51 AM
Need to remove baseboards that are glued and nailed recklessrick Painting 7 10-14-2005 05:20 PM
