Originally Posted by humberguy
thanks guys for your tips, the coping saw is a great idea but can you be a bit more elaborate with the method.
The idea behind a coped joint is to give the illusion of a perfect mitered corner, but of course corners in drywall are rarely a perfect 90 degrees so the cope joint solves the problem of 2 45's not joining properly.
say you measure out 1 wall in your room, cut a piece of baseboard with no miters and nail in place, next you want to make a cope joint on the pieces of baseboard that will join the piece you just installed, make a 45 miter as if you were installing it to meet another 45 miter..... then with the coping saw you want to cut the profile of the baseboard out, i.e if your using pre primed baseboard you want to cut along the line with the primer meets the edge of your miter, this will give you your profile.
Good tip: when you slice your miter on the piece to be coped, take your pencil and darken then edge your cut will be following, it
makes it much easier to see
Also, you want to do roughly a 45 degree back cut on your coped joint so the baseboard can move in or out depending on the wall
