Baseboards - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-18-2008, 12:09 AM   #1
baseboards
What is a fair price for having baseboards installed. I have been quoted $1.25 per lf. Is that too much, it sure seems steep to me?
hammer is offline   Reply With Quote
Old 02-18-2008, 07:12 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
There are other factors that can affect the pricing.
1.) What area are you in?
2.) Is it a one piece base, or are there sections to it?
3.) Is this stain grade or paint grade?
4.) Is it on harwood flooring, or will the areas be carpeted?
5.) Will the installer be required to plane the lower run of the base in areas?
6.) Is this new construction or a remodel?
7.) Are you providing all the materials, fasteners, adhesives, etc?
8.) Is the installer able to set up and cut in the locations that they will be installing in, or do they have to set up in a specific location and work everything out of that area?
9.) Are there any other time consuming aspects to "your baseboard install job"?
10.) Are there any other labor instensive details that are connected to "your baseboard install job"?
Aside from that, the rate you were quoted, is a reasonable rate in my area for paint-grade, one piece, Base Board installation.
- Build Well -
Old 02-19-2008, 07:56 PM   #3
Trim work is not for the faint of heart.
As the previous poster mentioned, there are many variables.
--Scott
Last edited by AtlanticWBConst.; 02-19-2008 at 08:26 PM. Reason: Advertising Links Not Allowed: Removed
24hourapartments is offline   Reply With Quote
Old 02-19-2008, 08:14 PM   #4
I don't think its enough. I think you should pay them more.
nacko is offline   Reply With Quote
Old 02-19-2008, 09:37 PM   #5
I did baseboard throughout my entire house renovation, and it ain't easy, takes time, skills and patience. If they paid me a $1.25 a foot, I would run away
helpless handyman is offline   Reply With Quote
Old 02-19-2008, 09:55 PM   #6
PRO Siding Windows Roofs
seems cheap, I would only do it for $1.25 if it was basic, and had A LOT of baseboard.
PKHI is offline   Reply With Quote
remove caulking/chunky paint from baseboards stallinc Painting 3 01-31-2008 09:27 AM
Remove baseboards before carpet installation? digexpressions Flooring 6 12-17-2007 09:46 AM
HELP: Bleeding Baseboards Roztom1 HVAC 2 10-11-2007 03:10 PM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 07:48 PM
Need to remove baseboards that are glued and nailed recklessrick Painting 7 10-14-2005 05:20 PM
