Baseboard Vs Flooring Finish In New Construction - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-08-2013, 07:22 PM   #1
Rewards Points: 1,062
baseboard vs flooring finish in new construction
If I need to do both baseboard AND hardwood/carpet, is it better to do one and then the other and why?
Old 01-08-2013, 07:26 PM   #2
Rewards Points: 636
hard wood then base board and where the carpet is going install base board first held up 3/8 off floor if padding is used under carpet. then install carpet
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
The Following User Says Thank You to jaydevries For This Useful Post:
amakarevic (01-08-2013)
Old 01-08-2013, 07:37 PM   #3
Originally Posted by jaydevries
hard wood then base board and base board held up 3/8 off floor
Why elevate 3/8 above the hardwood?
Old 01-08-2013, 08:39 PM   #4
Rewards Points: 636
so the carpet installer will love you
the gap will let him tuck cut carpet under and it will put a little down pressure on tack strip while stretching and tucking
you might want to ask same ? in the flooring section also see what they say
Old 01-08-2013, 08:40 PM   #5
Framing Contractor
Rewards Points: 114
He is referring to the baseboard before the carpet. For the hardwood, you could install it after the floor and just set it on top.
sixeightten is offline   Reply With Quote
The Following User Says Thank You to sixeightten For This Useful Post:
Old 01-08-2013, 08:42 PM   #6
Rewards Points: 636
sorry i will edit so not to confuse some one
Old 01-08-2013, 08:50 PM   #7
now it all makes sense. thanks
Old 01-08-2013, 10:21 PM   #8
Rewards Points: 2,210
We always did both after, If you gotta come to do one better use of time to do both.
mae-ling is offline   Reply With Quote
The Following User Says Thank You to mae-ling For This Useful Post:
woodworkbykirk (01-09-2013)
Old 01-09-2013, 02:38 PM   #9
Question
why not install carpet before the baseboard?
Old 01-09-2013, 02:39 PM   #10
huh?!
Old 01-09-2013, 03:00 PM   #11
Out of curiosity, is there a benefit to installing baseboard first?
My home has baseboard sitting on the subfloor, same as the hardwood. I'd have preferred to have the baseboard sit on the hardwood and run a little higher up the wall.
Jeff180 is offline   Reply With Quote
Old 01-09-2013, 03:43 PM   #12
Rewards Points: 131
As stated, depends on the flooring one plans to go with....
If the floor is going to be hardwood ( or any other solid surface material I imagine ), that goes on first then the baseboard. The entire floor surface can then be prepped and stained right to the wall. Obviously one has to take the necessary precautions with respect to the newly finished floor - proper wait time for the finish to cure AND protection from errant hammer blows, raw wood, saw dust, etc.
If carpet is going down, then it "pays" to put the baseboard on before the carpet gets laid, with the noted gap for tucking the edge under. One could do baseboard post-carpet lay, but I fail to see any benefit in doing so, and I do see potential issues - notably irregular gaps and such.
Chokingdogs is offline   Reply With Quote
Old 01-09-2013, 05:02 PM   #13
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,060
for hardwood ALWAYS install after the flooring. if you do install it the hardwood guy will either tear it off or it will get damaged during the install
for carpet ive done it before hand but some carpet guys are clumsy when their installing and can hit the baseboard with their tools which can do damage
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
mae-ling (01-09-2013)
Old 01-11-2013, 09:09 PM   #14
Rewards Points: 636
if you put baseboard down after carpet is installed and it gets pressed down tight to carpet you will have one very bad person who ever has to tear it up before re carpeting due to the pressure being press down in to tack strip. trust me i know i have been that mad person and one time had to take base of to remove carpet due to tack strip being to close to wall and then after carpet base was put on being press down in to the tacks
Old 01-11-2013, 09:59 PM   #15
funfool's Avatar
Rewards Points: 534
When I did new construction, carpet was always the last thing to be installed.
Simply set base board on 1/2" blocks to keep it off the floor, carpet tucked under it.
And yea, stretching berber carpet, they always managed to beat up the base board.
funfool is offline   Reply With Quote
Plank flooring for new construction DidjaDewit Flooring 3 10-17-2012 05:56 PM
How to deal with wavy flooring - Baseboard mobiledynamics Remodeling 6 07-02-2012 06:52 PM
new construction flooring question bgabrielse Building & Construction 5 12-05-2010 05:52 PM
Allure Flooring from Home Depot Kitchen Flooring 0 08-23-2009 10:33 PM
Changing poly type during hardwood floor refinishing redpen Flooring 17 02-03-2009 07:11 PM
