Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 03-04-2007, 11:11 PM   #1
Baseboard trouble
We are putting in a half-bath and we had it sheetrocked, but the floor was already tiled and there is a larger space than regular baseboard covers. It is an old house and the baseboard has to be at least 6" so tha the original door trim will meet it properly. It has to be 2"+ thick to cover the edge. Anyone have any suggestions? We got a 1 x 6 and another piece of molding thinking it would do it, but it isn't quite thick enough.
my5cats is offline   Reply With Quote
Old 03-04-2007, 11:27 PM   #2
Baseboard trouble
Try a 2x6. But seriously you could use the 1x6, if you cut spacers where the studs are located then take colonial doorstop and put that on top to cover the empty space where the spacers are, then top that with true 1/4round 3/4 in. and use same where your base meets the floor. I have run into this type of made up base in some very old homes though the components were somewhat different.
Zero Punch is offline   Reply With Quote
Old 03-07-2007, 08:45 AM   #3
Baseboard trouble
Originally Posted by my5cats View Post
... but the floor was already tiled and there is a larger space than regular baseboard covers.
Is the flooring ceramic tile?
What color are the tiles?
redline is offline   Reply With Quote
Tile vs Wood as a baseboard MattCoops Flooring 12 05-27-2009 04:39 PM
Tile Baseboard leted_82 Flooring 3 07-07-2007 12:57 PM
Need help with finding very wide baseboard Showbiz Carpentry 2 05-28-2007 08:52 AM
Baseboard Question in New Home BusterPercheron Building & Construction 5 11-20-2006 07:16 AM
Remove baseboard heat? Patrick B HVAC 6 04-11-2006 05:12 PM
