Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 12-24-2010, 01:03 PM   #1
D-I-Y Man
Baseboard trim question...
I am installing the baseboard in my basement and I have everything done except for the stairs. Now I know how to do most trim but I am lost as to how to get this to work, my landing has two different stair heights so I am doing two separate "runs" of base with a return on the end however I cannot figure out how to cut the return on the angle I cut to match the wall. I have attached some photos to help explain my issue. I am using a one piece 7.25" base so after it was cut on the angle it is about 10.5" tall. Any advice would be greatly appreciated!!
jricharc is offline   Reply With Quote
Old 12-24-2010, 01:13 PM   #2
You mitered it at a certain angle. Put it back on the saw at the same miter and set the bevel at 45 degrees and cut the trim.
Take another piece of trim and cut the return and glue it on.
The procedure is the same as a return at 90 degrees.
Ron
Old 12-24-2010, 01:18 PM   #3
D-I-Y Man
I have the long piece already 45º'd on the backside ready for the return piece but I couldn't figure out what was the right way to cut the small return piece.
So use the same angle I cut the mitre with and cut that on a 45º bevel and then cut it straight just like any other return?
Old 12-24-2010, 01:45 PM   #4
You would cut the 45 degree bevel at whatever miter angle you cut. You would then return the bevel angle to 0 degrees(back to the upright position) You would then slide the wood over so you could cut off the pie shaped piece. Take it easy on the cut as the piece is small and long. Sharp blades and minimum force as you slide the saw to the fence will eliminate broke returns.
Ron
Old 12-24-2010, 06:44 PM   #5
Stair builder
This article on This Is Carpentry might help explain a couple of things http://www.thisiscarpentry.com/2010/...board-returns/
Keith
Keith Mathewson is offline   Reply With Quote
The Following User Says Thank You to Keith Mathewson For This Useful Post:
jricharc (12-24-2010)
Old 12-24-2010, 11:36 PM   #6
D-I-Y Man
Thanks Keith, I will see what I can get my hands on to try and make the piece by hand. I have never had to attempt anything like this before when doing my own trim.
Old 12-28-2010, 12:51 PM   #7
I have never seen baseboard on top of the skirt board on stairs, only OG molding, that is the molding on top of that baseboard. I would rip it out and use OG molding!
jerzeedivr is offline   Reply With Quote
Old 12-28-2010, 06:38 PM   #8
Stairguy
it is much easier if you level off the skirt and wrap it around the corner. Then use just the top part of your baseboard by ripping just the molding off. If you level off you skirt, the molding will level off, miter around the corner, miter down, then bisect down to the rest of the stairs.
Millertyme is offline   Reply With Quote
Old 01-01-2011, 10:30 AM   #9
+1
what he said.
II Weeks is offline   Reply With Quote
Baseboard heater wiring question Master Brian Electrical 21 10-07-2010 10:28 PM
Baseboard Heat 80% Rule Question bltglt507 Electrical 1 11-06-2009 12:17 PM
Interior Door Trim (am I the only one that does this?) javan Carpentry 17 08-14-2008 04:19 PM
Baseboard Question polar5554 Flooring 2 02-25-2008 02:08 PM
Baseboard Question in New Home BusterPercheron Building & Construction 5 11-20-2006 07:16 AM
