Baseboard Trim Question - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-30-2012, 08:05 PM   #1
Baseboard trim question
New to this forum but hoping someone can get me up the learning curve on trim work.
In short, I have two different height baseboard trims coming around a hallway opening. I don't care for the common option of ripping the taller trim shorter. I have attached a picture and would really appreciate someone giving me a few options. I have (6) of these to do (3- hallway openings)
Oh.... Pictures attached to show what I mean....
thanks!!
Baseboard trim question-trim-issue-overview-optimized.jpg   Baseboard trim question-trim-issue-detail-optimized.jpg
speparks is offline   Reply With Quote
Old 08-30-2012, 08:12 PM   #2
Rewards Points: 2,202
Use mouldings around the door way, casing and jamb pieces as if it was a door, do it up fancy
mae-ling is offline   Reply With Quote
The Following User Says Thank You to mae-ling For This Useful Post:
speparks (09-01-2012)
Old 08-30-2012, 11:22 PM   #3
AHH, SPANS!!!
Rewards Points: 1,166
Also, some type of plinth block perhaps that is tall enough to hide the height difference? maybe cut the block width at 3/8", set in from the corners of the opening and then wrap the baseboards around the corner butted into the block. The block could be 5/4 stock, and a simple way to dress out the top of the plinth is to (rip cut) use the top trim profile of your baseboard or with a router, any profile can be made (routed) to set atop of the plinth.
For the little baseboard pieces construction glue will hold them without any nails needed most likely...
hand drive is offline   Reply With Quote
The Following User Says Thank You to hand drive For This Useful Post:
Old 09-01-2012, 07:37 AM   #4
Thank you both very much for your ideas... I am leaning towards trimming out the opening like a door..... It will look very nice but I am not looking forward to more staining and poly...
Scott
Old 09-01-2012, 10:39 AM   #5
AHH, SPANS!!!
imo, it would be less work to pull the baseboard and rip it down to size and then install it back against the wall, can most likely be done without need for new base and old nails can be pulled out...
Gable trim detail question with pics mjzraz Roofing/Siding 9 11-06-2011 10:46 AM
Baseboard Heat 80% Rule Question bltglt507 Electrical 1 11-06-2009 12:17 PM
Measuring trim for mitered baseboard installation abbyqueue Carpentry 3 07-28-2009 01:54 PM
Baseboard Question polar5554 Flooring 2 02-25-2008 02:08 PM
Baseboard Question in New Home BusterPercheron Building & Construction 5 11-20-2006 07:16 AM
