Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 01-05-2013, 04:05 PM   #1
baseboard transition - Can't get that angle
Hello,
I am having a hard time trying to transition baseboard from my floor up to my stairs. I've read a few similar posts here, but I am not grasping the how-to of doing this(yet)
I would consider myself an absolute beginner when it comes to carpentry and I doubt I could describe what I am looking to do properly...so let me show what I attemping with some pictures.
1 of 3
2 of 3
3 of 3 - my attempt
It almost looks like it fits...but I did that with a lot of hacking and not method to my madness. I am trying to figure out what angle to use to cut the finial pieces. I borrowed an electric saw that can cut angles up to 60 degrees which I am using to make all the angles.
Any comments and help would be really appreciated
John
baseboard transition - Can't get that angle-1_floor.jpg   baseboard transition - Can't get that angle-2_floor.jpg   baseboard transition - Can't get that angle-3_floor.jpg
JohnDeknis is offline   Reply With Quote
Old 01-05-2013, 08:08 PM   #2
The staircase skirt board is usually not finished with another trim like you have. But at a brief glance, I think what you have will pass. Just wood filler, caulk and sand so you don't have gaps at transitions.
I would have cut the skirtboard to butt the trim, and use quarter round to finish the top of the skirt board.
carpdad is offline   Reply With Quote
The Following User Says Thank You to carpdad For This Useful Post:
oh'mike (01-05-2013)
Old 01-05-2013, 08:28 PM   #3
That looks like casing your tying to use for a base board.
I've never seen anyone trying to use that to cap a skiirt board.
More often it's cap moulding.
http://www.bing.com/images/search?q=...se+cap+molding
Also why why would you not sand prime and paint that skirt board before installing anything?
Old 01-05-2013, 08:31 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
if you have a multi tool, i would use it to cut teh skirtboard back closer to the first tread.. make the cut perfectly plumb and at a point that it will be atleast 2" higher than the baseboard. this way you can go with the 3rd picture shows only with longer peices which makes it cleaner
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
Duckweather (01-08-2013)
Old 01-05-2013, 08:35 PM   #5
Super Moderator
Number 3 looks good---your molding is a bit unusual for a skirt board cap---but I thin it looks rather nice---
Carp Dad offered up a good bit of advice---I like to glue in the small bits of trim--brads will often split them---
Old 01-05-2013, 09:19 PM   #6
Mod
kwikfishron's Avatar
Base never looks right running up the stairs imo.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is offline   Reply With Quote
The Following 2 Users Say Thank You to kwikfishron For This Useful Post:
12penny (01-06-2013), woodworkbykirk (01-05-2013)
Old 01-05-2013, 10:29 PM   #7
mikes right about small mouldings splitting. 18 gauge brads will split them .. if you have access to a 23 gauge use that .the micro pins wont split it
Old 01-06-2013, 08:28 AM   #8
Roofmaster
I think I would have plumb cut the end of the stringer, filled in a triangular piece to continue the stringer all the way to the floor on that angle then divided the remaining angle by two, cut and installed the trim. That does look like casing, but its kind of nice.
" A lot of men build things, and a lot of things fall down "
Old 01-07-2013, 07:17 PM   #9
looks perfectly fine to me other then it looks like your first long piece is to short. looks like you can stick your finger between the end of the stringer and base. i've done it like this and i see why your doing it, because the drywall around the stairs looks nasty! good job
princelake is offline   Reply With Quote
Old 01-08-2013, 03:15 PM   #10
Haverhill Trade 1965
Picture #1 looks like where your first piece should be not #2 or 3.
Duckweather is offline   Reply With Quote
Old 01-08-2013, 04:19 PM   #11
It looks like poly moulding, rather than wood. Is that still prone to splitting?
Seattle2k is offline   Reply With Quote
Old 01-08-2013, 04:45 PM   #12
if its hand nailed it can still split unless a pilot hole is drilled, mind you thats within the last 3" of a length.. gun nailing is no issue
Old 01-08-2013, 07:48 PM   #13
Stair builder
To me that looks more like case than base but either way I wouldn't run it up the rake run. If you wanted to pick up some detail to transition from floor to floor I would pick the top bead detail to carry up the rake. Cut the "base" square and slide it along the wall, over the skirt until you find the point where the skirt intersects the "base" at the bead detail, cut the skirt plumb at that point. Rip that part off of a piece of the molding and miter to run up the rake.
Keith Mathewson is offline   Reply With Quote
Old 01-08-2013, 11:06 PM   #14
after a closer look its actually a store bought boston header profile, its a simpler smaller version of what custom builders will have the trim carpenters custom build on site out of several pieces of trim
Wall tile to baseboard transition? wraiththe Remodeling 11 01-10-2012 08:29 PM
Problem with 240V Elect Baseboard Heater JRHP Electrical 4 10-04-2010 10:30 AM
Partial hydronic baseboard to radient floor conversion Jeepsail HVAC 4 01-17-2010 05:47 PM
How to transition from door casing to baseboard? RxScram Carpentry 12 11-14-2009 12:10 AM
Baseboard dilema Allyson Flooring 5 09-04-2009 09:30 AM
